LQ4 cam / springs help
Old Jun 5, 2023 | 10:05 PM
Alpha_numeric44's Avatar
Default LQ4 cam / springs help
So I picked up a set of 706 heads to run on my LQ4 6.0.
They came with a valve job, seals, and blue LS3 springs.
I'm planning on a BTR Truck Norris cam.
(previous owner of the heads was running an Elgin stage 2 cam also on an LQ4.)
My question is are the LS3 springs a decent match for the Truck Norris cam?
-Specs of the Cams-
Elgin stage 2228/230 d at .05 .585/.585 lift 112lsa
TNorris 212/22x d at .05 .552/.552 lift 107 lsa
** Bonus Question **
The Truck Norris cam set comes with 7.4 pushrods... am I cool to use these, or do I need to measure and all that
Old Jun 6, 2023 | 12:26 AM
My question is are the LS3 springs a decent match for the Truck Norris cam? (Yes, they should be fine)
-Specs of the Cams-
The Truck Norris cam set comes with 7.4 pushrods... am I cool to use these, or do I need to measure and all that? (Should be fine, BUT always good to measure)
See answers in parentheses....
Old Jun 6, 2023 | 08:25 AM
68Formula's Avatar
The previous owner was running LS3 springs with a .585" lift camshaft? I thought you risk binding above .570" with those.
Old Jun 6, 2023 | 09:34 AM
He must have been running them at the ragged edge....
Old Jun 6, 2023 | 10:56 AM
so I'll be OK with the .552 truck Norris and these springs?
Old Jun 6, 2023 | 12:16 PM
Found my answer
Theyll be fine
