Rocker Bearing Failure
Old Jun 26, 2023 | 07:06 PM
bencormier's Avatar
Default Rocker Bearing Failure
I have a 99 Camaro SS that just had a rocker needle bearing failure. I found 24 needle bearings under my valve cover and will drain my oil and see if I can get the rest. I have read some other forums on people saying that if you don't get every single needle bearing out of the motor you will have engine failure. I have heard some people saying that the needle bearings are too big to be sucked up through the oil pump and will therefore just sit in the bottom of the oil pan and cause no harm. I will be replacing all the rockers to avoid this again, but do I have anything to worry about If I can't find every needle? Will I need to drop the oil pan?
Old Jun 27, 2023 | 02:30 PM
MuhThugga's Avatar
They won't get sucked up by the pickup tube as the screen will prevent that. I'd pull the valley cover under the intake to make sure none are resting in there, but you'll most likely find them all near the failed rocker. You can always pop a magnetic drain plug in the oil pan and see if it picks up anything.
Old Jun 27, 2023 | 06:05 PM
I wouldn’t bother with the valley cover. It’s impossible for anything to get up in there except oil mist.
Old Jun 27, 2023 | 07:03 PM
MuhThugga's Avatar
Yeah, you're right. I've been working on Gen I and Gen IIs lately, so they've been on my brain.
Old Jun 27, 2023 | 07:42 PM
Understood, you're off the hook THIS time. LOL!
Old Jun 29, 2023 | 03:31 PM
bencormier's Avatar
Thanks guys I'll for sure look into these.
Old Jul 9, 2023 | 01:33 PM
bencormier's Avatar
Hey guys just wanted to give a little update. I went with the Trunnion upgrade kit from Comp Cams and got them all installed. I changed oil and found a few more needle bearings then decided to fire it up. I can still hear a tick but I don't know what it could be. Was hoping to get some opinions on it. Video may not do justice but thought it was worth a shot. I'm thinking maybe lifters?
File Type: mov
Old Jul 9, 2023 | 02:14 PM
I’ve noticed that all trunnion “upgrades” amplify any valvetrain noises that may be present. I’ve also read the same here on Tech that others noticed a noisier valvetrain after a trunnion “upgrade”. I’m sure what you may..or may not…be hearing is normal for the mod.
 Michael S. Palmer
Old Jul 9, 2023 | 04:54 PM
01CamaroSSTx's Avatar
How many miles are on this engine and what have you inspected and/or replaced for parts? Just putting new rocker arms on a high mileage engine may not cure a noisy valvetrain. You could have excessive wear on the camshaft, lifters, pushrods, valves, guides, springs and valve seats.
Old Jul 9, 2023 | 05:04 PM
bencormier's Avatar
I have 86,000 miles on motor. Upon reviewing the parts list the guy I bought it from, supposedly he did put new lifters in. He also put in pushrods, springs, texas speed cam and headers. I don't know the exact specs of these although I wish I did. I did inspect push rods while I was in there and all looked good.
Old Jul 9, 2023 | 05:18 PM
Unfortunately a visual isn't going to answer many of the questions pertaining to the valvetrain but you may be able to pinpoint which valve is ticking and go from there.
Old Jul 9, 2023 | 10:46 PM
vette4fl's Avatar
Did you check valve lash?
Also since you don’t have the cam specs, it may be worth checking the pushrod length. All you need is a Comp length checker, and a offset wrench to turn the engine over from the passenger side.
This wrench will fit both a stock hub bolt and an ARP bolt.
TEKTON 24 x 27 mm 45-Degree Offset Box End Wrench | WBE24324 https://a.co/d/5qDqhZS
Old Jul 10, 2023 | 12:57 PM
bencormier's Avatar
Are the valves adjustable on stock rocker arms?
Old Jul 10, 2023 | 01:13 PM
bencormier's Avatar
I was just looking at other forums and seeing what people have to say about ticking noise in the LS1. A couple people have said they have never heard of an ls1 without a tick. Am I just worried over something that is normal?
Old Jul 10, 2023 | 05:31 PM
More than likely yes. As I said above, the trunnion upgrades amplify an already noisy LS valvetrain, because it makes the rocker fulcrum more rigid. The LS platform has an inherently noisy valvetrain. I bought a brand new 2020 GMC savannah for my business a couple years ago, and it’s ticked since day one. Had 4 miles on it and was ticking. Still has same tick today. It’s not obnoxious but as an engine guy, I notice it.
Old Jul 10, 2023 | 05:33 PM
vette4fl's Avatar
No. This is why you need to make sure the pushrod is the correct size at zero lash. It’s a simple exercise, you only need one valve cover off, and there’s a million videos about this on YouTube.
Yes, stock lifters allow some ticking. Yours sounds louder than mine, for example. Not enough to panic, but because of the type and extent of the mods by the PO, it would be prudent to eliminate a certain common shortcoming by lazy people. An hour or two on your part is worth the knowledge and peace of mind, don’t you think?
Old Jul 12, 2023 | 09:34 AM
bencormier's Avatar
yes of course I will look into it.
Old Jul 12, 2023 | 10:41 AM
You REALLY don't know how the LS valvetrain works, do you??
