Ls swap should i????
Old Jul 2, 2023 | 10:25 AM
Actually it would be a single post sticky
"You're changing your camshaft. You WILL need a tune."
Old Jul 2, 2023 | 11:37 AM
02*C5's Avatar
welp let’s get the mods to do it 😂
Old Jul 2, 2023 | 02:11 PM
Caddydaddy84's Avatar
Rite on I understand stand now thanks for the explanation, but got another question while doing this is there anything I could should delete from the motor while doing the tune? I had a lt1 350 back in the days and I remember doing some deleting when I removed the smog pump off the motor then got the pcm tuned to delete vats, governor, the down stream 02 sensors, fan speed etc
Old Jul 7, 2023 | 03:25 PM
Question, is there such thing as a better year/gen 6.0??
Old Jul 7, 2023 | 05:15 PM
Graham Dwernychuk's Avatar
The 1999 6.0L cam with a long crank. So look out for that
Old Jul 8, 2023 | 06:45 PM
I'm having second thoughts now on the 2000 6.0 seems the be the lowest hp out of all the 6.0s?
Old Jul 8, 2023 | 07:37 PM
it’s been a fun power plant in my car, my car only weighs 3000 lbs tho
Old Jul 8, 2023 | 09:34 PM
My car is 2000 pounds lighter then a yukonbso mite be a factor?
 Michael S. Palmer
Old Jul 11, 2023 | 11:41 AM
biketopia's Avatar
If you're going to change the cam anyways, don't worry about what the stock power is. If you want to bump the power do like suggested and put one of the summit truck cam's in it. You could also have your heads cleaned up a little to bump the compression and or pick up a set of 799 heads for cheap, new springs seals deck it and go. If you go 799's you'll probably end up needing to run midgrade at a minimum and premium preferred to get max power without spark knock though. As far as anything else in the motor, if you're doing a cam do lifters, lifter trays, new head gaskets, new stock bolts and you're good. You could change your oil pump while it's out if you feel the need. Wouldn't touch anything in the bottom end. How many miles are on this engine and did you hear it run before? If the stock yukon intake will clear the hood leave it as well.
Old Jul 11, 2023 | 01:55 PM
Thanks for the words.. its a lq4 with 317 heads and milage I'm not sure because the seller said it was a re manufactured motor in the truck. I was thinking going SUM-8701-1 cam with ls6 springs and some headers
Old Jul 11, 2023 | 02:28 PM
The 2000 LQ4 was less powerful ONLY because the first few years it shared the 5.3L LM7 cam (191/190), then when the LQ9 came out, the LQ4 also got its cam (196/201).
Old Jul 11, 2023 | 02:42 PM
  #32
Oh I see good Info so a new cam would bump it up then
Old Jul 11, 2023 | 05:35 PM
  #33
So how can I make a early lq4 to get 400 hp with no spray
Old Jul 11, 2023 | 05:52 PM
  #34
Put some 243/799 heads on it, then put a mild cam in it. It will make 400HP by accident.
Your compression will be 10.2:1 if you use a .040 gasket
Old Jul 12, 2023 | 12:28 AM
  #35
What about some 706 heads? I think those are 64 cc? And would that bump up a compression ?
Old Jul 12, 2023 | 12:38 AM
  #36
706 heads have 61cc chambers and a bit smaller ports than 243/799 heads. If you're looking for low end power these will deliver.
With 706 heads you will have about 10.42:1 compression.
I would lean more towards the 243/799 heads myself. Better breathing higher up.
Old Jul 12, 2023 | 02:55 PM
  #37
Oh they are 61 cc heads yikes know I know cool thanks so the other heads you mentioned have the same cc?
Old Jul 12, 2023 | 03:38 PM
  #38
Oh they are 61 cc heads yikes know I know cool thanks so the other e heads you mentioned have the same cc?
"e heads"??? The 706 heads are the smallest LS head chambers.
Old Jul 12, 2023 | 03:59 PM
  #39
LS1 TJ's Avatar
Just a thought. Since its a 6.0 maybe L92 heads? LS3 type intake?
Old Jul 12, 2023 | 05:15 PM
  #40
Likely not a bad idea, max power would be up some, but part throttle low RPM response will be a bit soggier, which in a Caddy barge might not be as desirable.
