Biggest cam for Lq4?
Old Jul 12, 2023 | 12:12 AM
02*C5's Avatar
Originally Posted by 65gmcC10
Im still yet to find a transmission, so it may not be the T56, but rather the T56 family, mabye Tkx, Tko, Magnum, etc. I guess im just not really getting how the 8711r1 would be so terrible down low. Richard ran it on a 5.3 and it was an improvement over the LS9 cam everywhere. He said himself that the Ls9 cam has a soft low-end, but is it really that bad? im also assuming that a 6.0 would handle the low-end better than the 5.3? About compression, assuming it wouldn't cause PTV issues, I wouldn't be against running a thinner head gasket to give a bit more of a compression bump. Might have forgot to add, but just thought I better say that this truck really wont be doing any "truck" things like towing, hauling a load, etc.
The reason some of us are giving you advice and trying to steer you a different way is because of real life experiences in our vehicles. Richard knows his stuff he just does but many of us have tried cams that were supposed to be home runs and they are up top and very sluggish down low in heavy cars. You can do as you wish it’s your money. But remember advice is free and mistakes sometimes cost money.
Make sure you have the right diff gearing for the cam. I wouldn’t go with less than a 3.73 even if you’re not towing. I would definitely go with a Magnum F out of the group. It’s geared with a 2.66 first gear and countershaft (close gear ratio) and you’ll be able to put plenty of tq through it. In stock form it’ll handle 700ft lbs. Remember with heavy vehicles it’s more about how much tq your trans and clutch handles more then hp for longevity because weight plays a role.
What type of rear end are you going with?
Old Jul 12, 2023 | 03:01 AM
65gmcC10's Avatar
I understand, and I really appreciate the guidance. I'm 17, so definitely less experienced than many of you on here lol. For transmission, The magnum would definitely be my choice, money aside, but that may have to be determined at a later date. I will definitely keep the gear ratios in mind. In terms of rear end, I was thinking about the GM 10 bolt 8.5in. I still have to do my research but as of now it seems it may be a much easier, and possibly more affordable swap than some others, even with possibly upgrading whatever necessary. Another option is a 04 suburban 3/4 ton rear end, axels and all, which I already have laying around. I've heard these can be pretty solid rear ends, as long as I keep launches with sticky tires to a minimum. I don't have measurements or anything yet, But I'm just a bit concerned with the fitment of that, along with the track width.
Old Jul 12, 2023 | 03:18 PM
02*C5's Avatar
I’d definitely go with the suburban rear end a much more stout and robust rear end. Again we are just trying to help. And in 20 or 30 years you’ll be in here talking to another 17 yr old kid wanting to make sure he doesn’t throw away his money. Good luck buddy glad to see young men still interested in wrenching and the go fast trade. 🫡
Old Jul 12, 2023 | 08:09 PM
wannafbody's Avatar
I was at the road course a few years back. A guy had a 2000 Mallet Corvette. That car originally came with a 240ish degree intake duration cam and could barely idle. Maybe retuning would help but a smaller cam would have been better all the way around. So something around 240 duration can work but not well.
Old Jul 12, 2023 | 10:46 PM
65gmcC10's Avatar
Post
thanks! and yeah, the suburban rear end may be the route I go, just gotta check the measurements and everything to make sure it'll somewhat fit
Old Jul 12, 2023 | 10:48 PM
65gmcC10's Avatar
Post
Yeah, I wouldn't want to put a 240 intake duration cam in, not sure if it would even work as the intake valve is what would hit first and I think a 240 would be pushing it. Thanks for the info though!
Old Jul 17, 2023 | 02:02 AM
65gmcC10's Avatar
Hello again, im just kind of finalizing my choice of cam, hoping maybe someone has ran one of these or similar. Its between the summit stage 3, summit stage 4, and Btr stage 3. Will include links below. The summit stage 3 is 232/242 113+3, .600/.600 Lift, and the BTR stage 3 is 231/244 .630"/.615" 112.5+2.5. The durations are pretty close, but How much power would I really be gaining with the extra lift on the Btr? The Btr stage 3 lift is more that the summit stage 4!? Then That brings me to the question of how much more bottom end will these stage 3's gain over the stage 4? I know a stage 4 will be rougher down low and all, but say it was in a race scenario, would the stage 3's just pull harder down low enough to compensate for the little bit they may loose at the top end? Also, This engine will probably be revving in and around 6500rpm, mabye less. Based on dyno graphs It seems like I may not be maximizing the potential of the stage 4 at that rev range? if thats the case, would the stage 3's make about the same power up high since i may not be revving high enough to even let the stage 4 really gain its advantage? thanks again.
Summit stage 3: https://www.summitracing.com/parts/sum-8708r1
Btr stage 3: https://briantooleyracing.com/btr-ca...-33142123.html
Summit stage 4: https://www.summitracing.com/parts/sum-8711r1
Old Jul 19, 2023 | 05:12 PM
02*C5's Avatar
I ran something similar to your top choice is was a custom grind. It had a tad bit more of lift .615 in and out and the intake lobe was 234. I used it for nitrous. I was making a solid 538 rwhp on a mustang dyno through an auto on the juice and 414 off the bottle. I revved it to 7200 rpm’s with ease and no issues but the power didn’t start to come in till about 3200rpms. I was lucky because it was a corvette and it was a light vehicle 3480 with me in it at the time. Oh and it was on a 112 LSA.
Old Jul 20, 2023 | 12:27 PM
65gmcC10's Avatar
right on, another quick question for anyone on here. If I am going to run that summit stage 3 that I listed, I guess I would also step the springs down to maybe the BTR 0.630"s to be a bit easier on the cam, lifters, etc. I was wondering how this would affect a boosted application when compared to the BTR 0.660" kit. Since the 0.630' kit says " naturally aspirated applications only.". Am I better off going with the 0.660" kit since I would like to boost in the future?
Old Jan 2, 2025 | 08:01 AM
John Salary Jr.'s Avatar
That’s not really that big. Some cams for LS1 have run a 242/248 on a 110. If you’re looking for the BIGGEST cam you need to dig a little deeper. If you’re looking for a max effort cam you can also have a custom ground cam for what ever application you want.
Thank you
Old Jan 2, 2025 | 09:38 AM
Abs's Avatar
Abs
Originally Posted by John Salary Jr.
Thank you
possible scammer acct trying to get more posts?
Old Jan 2, 2025 | 10:53 AM
  #32
Patrick G's Avatar
LS1 Tech Administrator
Doesn't appear so but thanks for keeping an eye out.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
