Biggest cam for Lq4?
One last question, the Comp 54-469-11 can be found on summit for $515.95, yet summit has a cam with simmilar specs, for $299.99. Will include links below. Is it really worth the extra money for the Comp? I am also not sure if the Summit cam will clear, as it is slightly larger. Any help or information is greatly appreciated.
Summit cam: https://www.summitracing.com/parts/s...make/chevrolet
Comp cam: https://www.summitracing.com/parts/c...make/chevrolet
In a heavy car you want power made as early as possible in the rpm range so you can get that thing moving and moving quickly out the gate.
So unless you’re looking to do a max effort 6.0 do what most people with common sense do. Get a cam that will fit your every day driving that way you have usable tq and hp in the rpm range you’re going to be at majority of the time.
If you’re dead set on a max effort cam go with a max effort cam but it gets old after a while especially if majority of your time in that vehicle is on pavement not the strip.
8711r1: https://www.summitracing.com/parts/sum-8711r1
Here’s a cam that will in my eye be a better shot e. Look at the charts. Remember that these cams are made to make power and tq. Designed for trucks.
https://briantooleyracing.com/btr-ge...orris-cam.html
You'd be much better off with the 8707R1. No ones going to be impressed with the size of your camshaft when the Pruis in the next lane bests you the first 50 yards.
I’d go with higher compression smaller cam which will make more power at lower rpm’s.
Now if you add some 3.73-4.10 rear gears, stepping up to the 8710R1 is workable but it'll want to be shifted 6500+rpm to get the full benefit. Still be a little soggy part throttle without the gears, but liveable until the upgrade.
That 8711 wants even more compression, ported heads, lighter vehicle, 4.10s, etc. And/or more cubes.
Your throttle body will be limited to 90mm with the TBSS (92mm if you port the manifold throat out - honestly not worth the work unless it was a strip vehicle). Going bigger by using an adapter doesn't gain anything if the manifold throat is smaller than the throttle body bore.
