Is a build even worth it?
Aaftermarket heads and valves and a cam with complimenting parts is usually at least $4000 in parts.
Housing, center section, axles, all the little bits and pieces to complete it.
Plus the cost of having a shop install it like he prefers.
Also your not gonna want to use the stock trans and converter
Add a built trans and quality converter, plus install.
Damn near $10k!!!
One of the reasons I switched to Vettes lol, less stuff you have to upgrade initially.
Damn near $10k!!!
housing and axles is about $1100 (quick performance), then a rebuilt 9" bronco posi about 500-600, and you could use stock drive shaft. so roughly 1700, but if he's paying install that would probably be 6 hours labor so roughly 600-1000 to install. Not bad, considering he is contemplating 5 grand for heads and cam. **** for 5 grand I'd buy a turbo kit. or SC.
