Is a build even worth it?
1) how much you want a hp gain
2) your financial situation
3) condition of the vehicle
4) emissions & inspection requirements where your located
In 2002, doing heads & cam on my 99T/A was definitely worthwhile and with headers & rear gears cost about $6,000 total.
In 2022, doing heads & cam on my 02 Z28 with 263,000 + miles...I decided maybe not worthwhile. $5,000 for H&C will probably turn into $10,000 for a new headers, transmission & new torque converter.
Good luck whatever path you take.
What have you got now? Have you tried a tune from someone knowledgable? What do you wish it would do? HP #s aren't the correct answer... something like ETs, 0-60 times, etc. would be a better gauge. How much are you willing to spend? How much of the work will you do yourself? Keeping in mind, this is a HOBBY... you'll go BROKE paying someone else to indulge in YOUR hobby on YOUR car FOR YOU, like the Vette guys do. Us F-body and truck types, no way. I'd rather pay for MY OWN kids' braces and college funds than somebody else's. If you're not doing the labor you probably have no business messing with your car.
The only thing stopping you from doing something is you.
I got longtubes ls6 intake magnafliw catback
I saw no point in building another stroker when I won’t have a local track to use it at and with heavy traffic no where to stretch the legs on that level of build out for a few gears.
I had my old LS1 sitting in the garage so it made the decision easier to keep costs down. I just want the car to run and still make decent power.
If you’re honest with yourself about what kind of performance you’re looking for out of the car it will let you know if it is worth it or not.
5k +\- for a low 11 second car or better vs $14-20k for a stroker is a no brainer.
if you get bored of the power you can always throw a 100-150 shot at it and still be well below a stroker
My stock trans let go and I had an aftermarket cooler added and kept the fluid clean on my other Fbody that was cam + full bolt ons. Some have had luck and others like me didn’t.
No matter what route you take, the trans, converter and rear will need to be addressed sooner than later as it will be the weakest link.
