Could I just bolt in another crank without machining?
Old Jul 27, 2023 | 01:03 PM
97camer's Avatar
Default Could I just bolt in another crank without machining?
I ended up with a early 6.0 long crank i think ( it won’t turn over by hand with the tranny bolted up and they say if there is 3/4” sticking from the seal it’s long)
can I bolt in a short crank without machining,or could it be done without takeing out the pistons? Put in new bearings with it ? Hope I didn’t crush anything in the tranny when I bolted it up, funny it bolted in ok for haveing a extra 1/2” of crank. What a mess!
Old Jul 27, 2023 | 01:12 PM
The extra 1/2" of length only comes into play when bolting up the flywheel and tranny.
IF the new crank is in new or nearly new condition, and
IF you put in all new main and rod bearings, it should go together and run without issue.
Old Jul 27, 2023 | 01:52 PM
You have likely hurt the pump in the front of the transmission, if it’s locked up. I’ve seen it done before, and the pump was hurt. To change the crank, the engine has to come out. Front and rear covers must come off, oil pump, and timing assembly, come off also. You’d need 8 hands in the block to hold all the rods in the exact spot it would take, to just set the crank in, which would almost impossible. That, and you will want to check bearing clearances, which involves mocking it up a few times. So your either pulling the engine, and doing a complete tear down, or finding a tranny that will work with that crank. Question…are you certain that you got the converter to go all the way back into the trans, with the “notches”? Seems like there’s 3 indentions, or notches that allow the converter to slide all the way back. Not doing this before you install the trans will lock it up just as you describe here.
Old Jul 27, 2023 | 04:51 PM
strutaeng's Avatar
You bolted up a long crank LQ4 w/o realizing it was the long crankshaft? Yikes!
I'm surprised it even bolted up without cracking the bellhousing. But you didn't run it, correct? You said it won't even spin over by hand. If you could determine that the transmission pump wasn't damaged, I suppose just order that custom torque converter for this application and move on. That way you don't have to mess with engine internals, especially if it's a runner.
But I would honestly remove the transmission pan, valve body and pump to inspect before anything else. Or take it to a transmission shop for inspection. Is it a known good transmission? What transmission is it anyway?
