Need help
Old Aug 14, 2023 | 01:41 AM
Mezzy's Avatar
Default Need help
Hi guys,
Could really use some advice. I have a 2002 LS1. Have a cam in it. I over revved my engine. I'm now here a tapping noise in the driver's side valve cover. Could this be a bad rocker arm or lifter with some air in it? Would putting in some Lucas oil stabilizer do anything to remove the air in the lifter if it is the lifter with air in it? Or do you think it's more likely a bad rocker arm?
Old Aug 14, 2023 | 06:14 AM
Old Buzzard's Avatar
It could be several issues..
Broken rocker, bent p rod, lost needles in the rocker, damaged lifter.
For starters, how about just pulling the valve cover and taking a look?
