Burning oil. Low miles
Old Sep 17, 2023 | 05:08 PM
chalou88's Avatar
Default Burning oil. Low miles
Hey guys. Quick background to get it out of the way. LM7 5.3 in a 2wd truck Low miles, like 110k. I have been noticing a little tail pipe smoke, mostly at idle cause thats the only time i am out of the truck to see it. I changed my oil the other day and I MUST have been low like a couple quarts due to the small amount that drained. But no engine noise, no ticking, motor seems healthy as always so I was kind of dismissing the smoke until the oil change. It is not leaking and it is not contaminating the coolant…My first thought was rings. But now I am wondering maybe valve seals, or even guides? Just need a little help diagnosing, what to look for. Obviously I will be keeping an eye on the oil level going forward. And i am not typically hard on the truck by any means so I an a little stumped. What preliminary things can i start looking for that doesn’t involve a massive tear down. I do have a leak down but are there even more simple tests?
Old Sep 17, 2023 | 06:22 PM
RB04Av's Avatar
What did the oil look like? Any sign of a milky tint?
Old Sep 17, 2023 | 08:03 PM
chalou88's Avatar
The oil looked normal. No milky tint. I always change my own oil. I did not see anything unusual other than what seemed to be only a small amount drained out. I guess i gotta just start straight with the leak down and see what I can find.
Old Sep 17, 2023 | 08:40 PM
How many miles on the oil? I ask because the LS engines use oil. The GM PCV setup pulls a lot of vacuum and it sucks oil mist into the intake. I change my oil in my daily ‘12 silveraydo and our work van fleet every 3-3500 miles. They are all….even my brand new vans….always almost a quart low at 3-3500 miles. If you stretch your oil changes out to 5k or more, your prolly low on oil. The PCV in these engines draws a lot of oil into the intake, in the name of emissions. It’s BS. Makes a mess in the intake. Turns into a jelly like substance in the intake. Just a thought…
Old Sep 17, 2023 | 09:41 PM
slothman's Avatar
i would check for oil leaks. put dye in it. maybe it's leaking slowly.
could also be the valves or piston rings. compression test would help.
Old Sep 17, 2023 | 10:47 PM
chalou88's Avatar
Tbh I dont know the mileage. Its coming up on 3 months. It is probably over 3000 but not sure by how much. I did drive it a lot more than usual this summer. I thought oil consumption was more common with the AFM motors around 07 or so? I forgot to mention. This is an 04. So pre AFM. At any rate, what would explain the smoke?
Old Sep 18, 2023 | 11:43 AM
grinder11's Avatar
My 2000 LS1 used enough oil (no smoke, thanks to cats) that the first few times I took it to the strip, it used more than I thought. I noticed each time I ran it, the runs got slightly faster than the preceding runs the week before. In a C5, a low oil light comes on eventually (if it's working correctly!). Mine came on just after my last run of the day, which was also the fastest trap speed I'd ever had at that point. I knew it came on when there was still about 4 qts of oil left in the sump. Glad I brought a couple qts with me! So I dumped a qt in it to get home, then changed it. So, some early LS1s also use oil. My car had under 30,000 miles when this happened. Like quite a few early LS1s, it also had the common LS1 piston slap when under 55° ambient temps prevailed....
Old Sep 18, 2023 | 12:57 PM
chalou88's Avatar
Thanks for the insight. I actually do not have cats. Maybe that’s the reason for the small amount of smoke?
Old Sep 18, 2023 | 08:51 PM
Old Buzzard's Avatar
Talking ??
No cats, so could it be your dog??
JK!
I've had a couple of the earlier 5.3's smoke very little but use oil as Scott mentioned.
Both were higher miles. New valve seals did reduce it considerably.
Old Sep 18, 2023 | 09:18 PM
I failed to mention my go-to first step procedure for diagnosing this issue, in my above post, and that is pull the spark plugs. Plug…or plugs…should show oil if it’s burning it. Maybe post up pics of plugs for us.
Old Sep 19, 2023 | 05:52 AM
chalou88's Avatar
Thanks. Ill pull the plugs. Probably wont be till friday but I will post what I find.
Question. Shouldn’t I expect to see some oil on one of the cylinders? Correct me if I’m wrong. I thought it was #8 hole?
Old Sep 19, 2023 | 05:57 AM
01CamaroSSTx's Avatar
Open the blade on the throttle body and perform a leak down. If you hear hissing coming through the exhaust and/or the intake manifold on a cylinder where the valves are opened it will be due to worn valve guides.
Old Sep 19, 2023 | 09:45 AM
gagliano7's Avatar
You could also have bad valve seals. You could pull the valve covers and see if any of them looked damaged.
Old Sep 19, 2023 | 09:47 AM
grinder11's Avatar
Valves OPENED??? Do you mean closed????
Old Sep 19, 2023 | 09:53 AM
grinder11's Avatar
Sounds like guide seals if it smokes after idling for a short time. I once had a 350 sbc, which admittedly had a less desirable guide seal than Gen 3s, and after 5 minutes of idling, even with a cat, it was fogging the yard!! Eventually plugged the cat, limiting me to 45 mph on the way home! My guess is if you had cats, you wouldnt see much, if any smoke, at least right now.
Old Sep 19, 2023 | 04:34 PM
What I meant to say is worn valve seals and wouldn't the valves need to be opened in order to determine if the valve stem seals are bad?
Old Sep 19, 2023 | 06:44 PM
RB04Av's Avatar
OK, let's try again.
What did it look like when you popped the driver's side valve cover off?
Old Sep 20, 2023 | 08:33 AM
chalou88's Avatar
I wont know until Friday or Saturday.
I did not think that bad valve guides or valve seals would be visibly bad. Unless they are destroyed in which case i would have noticeable noise / heavy smoking ??
Old Sep 20, 2023 | 09:22 AM
From the outside, worn guides and/or seals will not show visibly.
Old Sep 20, 2023 | 01:20 PM
RB04Av's Avatar
Let's see what's in the VCs when you pop them off.
