Has anyone made 400 awd hp with a Ls1 ls6
Tony uses the YT rockers exclusively on his builds, I have them on mine, they are a solid rocker arm, nothing I am worrying about. What springs are you using? I have Manley Nextek springs rated at 170lbs installed and 446lbs open, I can't imagine a scenario where you would need more than that with what you're doing. My rockers are non adjustable.
part number 26926ts-kit or 26926ti-kit.
I'm probably going go with the TS kit as the car will rarely see 6500rpm plus.
will only see that on the dyno I'd say just for tuning purposes.
My TBSS is/was AWD, it's a solid 20% drivetrain loss on those. So figure you need at the very least 500hp at the crank to come close to your goal. I have a set of Tony's MMS235 heads on my engine, they are definitely great heads and exceeded my expectations, can't go wrong if they fit your budget.
62 rear 38 front.
Viscose drive torque split. Ill try and fine the exact specifications and post them up for all to see.
129 on the seat is too low for any NA build and will float badly with any kind of boost in the picture which effectively reduces seat pressure even more. (Once again we see a potential mismatch of components which others have touched on in this thread).
The hot ticket is stout seat pressure and modest over the nose....that will give you rock solid valve control all the time. 175 ish or there about (depends on other factors whether you need a little more or could run a little less) and low to mid 400's open is ideal (even around 400 with a milder set-up).
And I do use the YT Ultralites for 90+ percent of ALL my LS builds but the proper spring selection is important and required to get the most from them based on the cam aggressiveness (including lobe design) and intended RPM of the package.
Excellent rockers that are purpose built for HR valvetrain systems
Regards,
Tony
Regards,
Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
The following 2 users liked this post by Tony @ Mamo Motorsports:
Che70velle (10-08-2023), SlowTBSS (10-06-2023)
Regards,
Tony
Regards,
Tony
The valve springs are the ones recommended for the comp cam from comp cams.
The cam is a LSR 54 458 11 cam 227/235 113+4 and the springs are the ones that they recommended This is also listed on their website for that cam.
Rather frustrating then if they don't know what they are doing for such a major cam manufacturer.
These were also advised to use the comp cams 13702 Trunion upgrade kit with the stock ls1 rocker. But I prefer to go to full roller for that little extra life on the valve guides.
or will the factory rocker arms be OK with 7200rpm and that spring pressure?
All the AWD Holden / HSV cars I know of went boost to make decent numbers but this was back in the day (when these cars were new). The closest I know of was a guy up the road from me had a HSV Coupe4 with a 383ci stroker with heads and cam that made 200 rwhp @ all 4 wheels. Built and tuned by Sam's Performance.
He ended up going 402 ci turbo from memory and straight into the low 10s in 100% street trim and weight was well over 2 tonnes. It moved on the street, I can attest to that personally... He sold the car a long time ago with an LS3 in it.
There was also a guy on the LS1 Australia forums with a HSV Coupe4 that had a Higgins built 383 stroker package and was tuned by HPF,
Higgins heads
224/228 Cam
Harrop Hurricane 8tb manifold
Full exhaust system
Made around 215 rwhp @ 4 wheels. So, the manifold probably gave it a bit over the other Coupe4..
So comparing to these AWD cars on our conservative Aussie dyno, to double the 383 ci power @ 4 wheels with your mods in a 346 ci, I'm not sure will happen but best of luck.
Higgins heads
224/228 Cam
Full exhaust system
Higgins heads
224/228 Cam
Full exhaust system
Higgins heads
224/228 Cam
Full exhaust system
there is a few adventra cars in the 350awd hp range now with modern heads and cams that i know of.
I know I'm stretching the friendship big time to get to my target hp at all 4 wheels.
The closer to 600hp at the cratheir can get the better the chance of hitting 400 at all 4 wheels.
The bottom end package I have is capable of getting there. It's just cylinder heads that will hold it back for now i think.
I've actually taken the vy adventra driveline and shoe horned it into a LX hatchback torana.
FWIW my Corvette made 450 on one dyno and 475 on another with a slightly larger cam (232/234 @ 112), Fast 102 manifold, LS2 throttle body, long tube headers, 3" exhaust, and mysteriously ported stock heads with "Leroy" stamped on them (I'm the third owner, so that's all I know). With an AWD system I'm guessing that would have been around 400whp, maybe a little more depending on the dyno. So this goal seems very achievable to me.
The only drawback to that cam is that it wasn't fully alive until 4000 RPM. Still a fun setup with a 7k rev limit though.
It helps build dynamic compression ratio for low rpm torque.
Couple that with the 11.3 to 11.45 to 1 static comprescompressionit will preform quite well.
the Auto driveline in the adventra has been said to drain over 30% of hp out of the engine. That's why i have to get closer to 600hp to achieve my target hp
The issue the OP may have is that as he is in Australia, it will depend on whose dyno he runs it on. For example, a similar combo to yours would usually make low 400s on the vast majority of Aussie dyno. Yet, these cars when well set up, can still run 10s, I've seen it, so clearly can back up the specs. It's not intended to be an insult, just a difference between countries. Still, you never know. Will be interesting to see the OP results when he gets his car together.
The following users liked this post:
NSFW (10-08-2023)
Australian dynos read lower than USA dynos across the board from all reports and sources that I know of.
so something that makes 400 what in Australia will normally make 440 or higher on a USA dyno I believe.
#32
The only true measure of power is how it goes when the rubber hits the road. You get numbers from doing that, which are non-refutable.
Dyno numbers are only good when comparing to numbers from the same dyno, preferably under identical atmospheric conditions.
All other bets are off.
#33
What you are saying is so true about the dyno difference between Australia and the ones in the USA.
However, there's often differences in Dyno results between shops here too. I've experienced that. No change, just drive to a different dyno and the car produces quite a different result. I even had that happen when the shop I use moved from a 2WD to 4WD dyno. Thus, I don't worry about dyno figures like many other do. It's how the car performs that matters.
Shtstr (10-08-2023)
#34
If my setup with RWD means low 400s, then another 10% drivetrain loss sounds like high 300s.
#35
I expect you're right. I don't think the recipe changes, you need the normal max effort 346ci list of mods. Top notch tune, really big cam, very nice heads with lots of compression, Fast 102 manifold and big TB, twin 3" exhaust with 1 7/8 headers, etc. I would imagine that's what's needed to get anywhere close to the OPs goals.
