Head porting experiment (gone wrong)
Old Oct 28, 2023 | 03:41 PM
Utinator's Avatar
Default Head porting experiment (gone wrong)
I just wanted to share a little experiment I conducted on a set of "junk" heads. In case anyone has thought about adding "dimples" to a cathedral port head, I advise against it. Here's why:
Old Oct 28, 2023 | 04:51 PM
TrendSetter's Avatar
What did you do to the short sides?
Old Oct 28, 2023 | 05:12 PM
dixiebandit69's Avatar
Are you sure that there wasn't some kind of calibration error when testing the dimpled port? Those numbers seem damn low for what was done.
I remember about 15 years ago, there were some people talking about port dimples/ grooves, and how it was supposed to help fuel atomization...
And nothing ever came of it. To this day, all of the big names in port development still have smooth walls.
It kind of reminds me about grooved pistons/ cylinder heads back in the mid '00s. Supposedly a groove in the piston head or cylinder would drastically increase octane tolerance and decrease BSFC.
Lots of guys SAID they tried it with great results, but no one could give any concrete numbers.
https://garage.grumpysperformance.co...grooves.11674/
Old Oct 29, 2023 | 09:17 AM
Utinator's Avatar
I normally don't touch the short side. I only put the dimples in the first half of the "short side", but I stayed far away from the "short turn". The area where I put the dimples is supposedly slower. I was trying to increase air speed in those areas.
I saw an Eric Weingartner video where he dimpled a FloTec casting LS3 style head. I have been wanting to test this on a cathedral port head every since then. The dimples actually helped on the LS3 head. The theory behind this is that the dimples effectively "shrink" the port. Since the LS3 ports are so massive, it actually helps to make them smaller. Shrinking the ports increases air speed, which increases air flow. Since the cathedral ports, especially the 706, are so small already, the dimples hurt air flow. Making the 706 ports smaller seems to restrict airflow instead of helping it. Now that I know that, I won't be putting dimples on any cathedral port heads.
Here's the video I was referring to:
Old Oct 29, 2023 | 10:06 AM
Utinator's Avatar
The dimpled and non-dimpled ports were flowed back to back. There were no changes to calibration or any other factors. The first flow sheet I showed was from over a year ago. That head is on the 5.3L engine I built and sold last year. I just pulled out that sheet because that head still had the swirl ramp. I was curious if the swirl ramp would change anything, and it didn't look like it did. Other than the swirl ramp, the head from the first sheet and second were ported the same.
Old Oct 29, 2023 | 02:28 PM
68Formula's Avatar
Interesting. I've heard of dimpliing pistons and combustion chambers, but not ports.
Old Oct 29, 2023 | 06:13 PM
Anytime you commit to an experiment and you can acquire solid data from that, it didn’t go wrong. (talking about your title here) Data is data, no matter which way you or I hoped it would go. I’ll say this about what you’ve done…dimpling has its place, but as you’ve seen here, it’s not going to help a fast port. I’m super excited to see testing like this here on Tech!
Old Oct 29, 2023 | 08:18 PM
MuhThugga's Avatar
Agreed. Testing is done to prove or disprove a hypothesis. The hypothesis was formed based on logic and reasoning, but testing found that the basis of the reasoning didn't apply to the variable of a port shape with a higher velocity.
I saw that Weingartner video on the dimpled port, and partially dimpling the port showed a gain of about 3-5 cfm while dimpling the entire port showed a loss of 3-5 cfm. The partial dimple was done in areas where airspeed would be the slowest and the larger 5 cfm gains were seen at .600 and .700 lift points. I think the ultimate question is if the labor involved with dimpling 8 ports is justified by the benefits.
 Michael S. Palmer
Old Oct 30, 2023 | 08:57 AM
68Formula's Avatar
Exactly, which would also be dependent on combination and intended use. The improved flow and velocity looks to be across all valve lifts so the cumulative effect could translate to a decent benefit. One could use for an overall gain with no other potential changes. Or reduce the intake valve duration and therefore shifting the intake opening/closing events effecting the powerband. Or even keep the intake duration constant while increasing the exhaust duration to provide further benefit of peak power.
Also, the airspeed differences at lower vacuum levels could be more pronounced, allowing better throttle response and driveability. On a purely strip-use vehicle, not really important, but for street use, can be a benefit that wouldn't show up on a dyno. On an actual engine, the goal is to get the air accelerating as quickly as possible during intake opening, not necessarily worrying about a peak velocity, but it's a decent way to differentiate port flow.
Old Oct 30, 2023 | 10:31 AM
ddnspider's Avatar
What's your experience with dimpling and it's place?
Old Oct 30, 2023 | 07:20 PM
Utinator's Avatar
The dimpling I did, only took about 30 seconds in each area. So, I spent about 1 minute on that one port. All 8 ports could be done in about 10-12 minutes. You gotta add a few seconds here and there to reposition the head and squirt 4W-40 in there. If it gains 3-5 cfm, then it's worth it to me.
Old Oct 30, 2023 | 07:26 PM
Utinator's Avatar
Yeah, I agree. I was just hoping to see some gains. It seemed to work on that Flo-Tec head. It looks like the small cathedral ports really don't need any more air speed. I am hoping I can find a "junk" LS3 head locally. I would like to conduct this experiment on a stock casting LS3 head.
The machine shop said they have seen dimples in heads before. It worked on some heads, but not others. He mentioned the GTR and some Honda heads, but I don't remember exactly which one it worked on.
Old Oct 31, 2023 | 12:40 AM
Fast355's Avatar
A flow bench is a helpful tool but more flow does not always equal more power. A back to back dyno test would give better information here. I have also wanted to see setups pulled from ~1,000 to say 4,000 rpm with 1/4 throttle opening. Every dyno pull you see is 3,500+ rpm and WOT. I would also find BSFC and torque output at say 10% throttle and 2,000 rpm interesting.
I would also wager that dimpling the bowl was the flow loss, not the dimples in the port. You added turbulence to the side that should be flowing at the highest velocity, thus inducing turbulence. I bet that port was screaming too. Up for a test just dimpling the port floor on the manifold side at the entry of the port? The dimples in theory act much like adding epoxy to the slower flowing areas of the port.
I have also seen it said by an Engine Master participant and winner that year state that the ideal port would flow ZERO until ~0.300 lift. Flow under 0.300 is mostly lost to reversion.
Old Nov 2, 2023 | 05:56 PM
2Heavy4Fast's Avatar
My experience with dimpling the iron block ls heads is that even if done flawlessly, you won't gain anything more than maybe 6cfm, if that, and for the amount of time that it takes to do a good dimpling job, it's nowhere near worth the trouble. One way to look at it is how much is YOUR time worth an hour. Then figure up how much time it takes to do a really good hand-porting and dimpling job, and when you come up with your final "cost" figure, I guarantee you'll come up with a dollar amount that would pay for a nice set of CNC aftermarket heads.
I love to see that you gave it a try though, and I'm even more glad that you came here and shared the results with everyone. It's stuff like this that made me fall in love with this forum to begin with!
