Piston Replacement
Old Nov 27, 2023 | 04:30 PM
Paul Soto's Avatar
Default Piston Replacement
I have a 5.3 engine bored to 5.7, the machine shop left a cylinder very tight causing premature wear on a piston that started to slap, I can't find a replacement for my piston in my area, a friend gave me one but it has a line that sticks out on one side, same rod, both are flat and build by mahle, same size, I don't know where my set of pistons comes from. What do you think? I send it?
Old Nov 27, 2023 | 10:30 PM
1FastBrick's Avatar
You already stated it was a Mahle piston. It's just a later revision. If you look on Ebay there are a few used ones. The damaged one appears to be a later revision with the coated skirt. Here is a good used one.
https://www.ebay.com/itm/38622334916...Bk9SR5Lt9cKCYw
Old Nov 28, 2023 | 09:53 AM
Paul Soto's Avatar
Thanks dude, the problem is that I am in El Salvador and the shipping and import costs will be very high, I think it would be my last option
