Camshaft question
have fairly much settled on these specifications as the valve timing is spot on for my dynamic compression ratio to be around 8.62 to 1.
227/235@50
277/289 advertised duration. 006
110.5 LSA Plus 1.5
The cam manufacturer said yes they can do it and also gave me @.200 lift duration.
Ive never used the @200 figers so hopefully someone might be able to give me some details as to why it's important for the to even mention it.
Thanks in advance.
.200 lift numbers are interesting, but not really useful unless you’re comparing to other lobes.
Agree with Grubinski, depending on the rest of your setup, you may not like the driveability. Hope you have at least some 3.73s, a 3k-ish stall (if auto), and LT headers.
There is a really good podcast you can listen to, to understand a lot of this from billy godbold on the power and speed podcast. You should look it up.
https://4secondsflat.com/Cam_Design.html
However 0.200" it is another data point to to compare cams. Gives you an idea of potential area under the curve as the valve gets in the higher lift region and how it's accelerating over the nose.
I seem to recall Harold Brookshire (rip) using the same metric.
All of the various "intensity" ideas are merely a way to examine how fast the lifters are accelerated.
Look at a typical stock cam; the lobe looks like an egg, with a kinda sharp point for the lobe tip. It spends very little of the total open duration with the valve anywhere near wide open. Look at a typical racing solid roller lobe by comparison: it looks almost "square", with very steep sides and the valve at or near max lift for a MUCH greater portion of the cycle. THAT'S what "intensity" is all about.
Several cam mfrs include the .200" duration spec in their catalogs for exactly this reason. Bullet for example, speaking of Harold.
The rpm rage for the asa cam is 2000rpm to 7400rpm.
So this tells me I worked out all my maths correctly and it will be a bloody great cam selection for my engine with the 6.3'' connecting rods and 11.15 to 1 static comp when warmed up and the block expansion has played its part in the equation.
with this cam ported head upgraded inlet and custom 4 into 1 headers and full 3''custom dual exhaust system.
It should push the crank hp close to my target 600hp to achieve my target of 400plus adwhp on pump gas.
Hell yeah.
Hell yeah.
Things that are getting overlooked with the build is the longer rods.
With longer rods you can use a smaller cam duration as the piston hangs at TDC longer than a shorter rod.
The longer rod also has other advantages too.
The ring pack is higher up the piston helping burn all the gasses and the piston dwel time being slightly longer allowing more burn time for combustion process to happen. Gives a bigger bang for buck so to speak.
Also because the piston pulls away slower from TDC it allows the valve to open more before the piston hits peak speed and sucks harder on the then open valve at a higher lift.
Also it allows for slightly more time on overlap to create better exhaust scavenging between intake and exhaust overlap cleaning the cylinder of any unwanted Burt gasses that don't help make power.
So I'm effectively using a bigger cam by using a longer rod than the normal build sheet of a ls1/6 .
I have the option to bump the compression up higher yet when I do my heads.
If I drop from a 68cc chamber to a 65cc chamber with .010 out the hole cold ill have 11.83 to 1 static cold and close to 11.5 when warmed up.
This will push the dynamic compression upto 8.89 when warm and over 9.1 to 1 when cold.
So instead of the valve being open .050 it will be say .075 open.
08The heads are going to be Ported for as small as possible cc size and 300cfm flow. That is enough to support over 600hp at the crank.
Even with the longer rods piston dwell is going to help achieve the VE to each 600hp. Assuming a high velocity head flow with minimized CSA, and if the total CFM was calculated at valve lift with the appropriate bore size, I think the intake/exhaust durations are going to fall short. The intake manifold efficiency relative to head flow would have to be extremely high and plenum volume, runner length, and cross section perfectly tuned for that specific rpm range. Then of course, you have the exhaust efficiency and wave tuning to consider. With a heavily ported intake and large headers with efficient full flow through exhaust, I'd estimate at least another 10* duration added to both sides. And probably expect the engine will be run past 7k to reach it.
As for calculating the DCR with/without block expansion, I'm not really seeing the value here. One's not going to start a 600hp car that's sitting for hours, and immediately go full WOT. You'd let it get up to operating temperature first. In any case, any potential concerns about donation due to a difference in DCR would be offset by not being up to operating temperature. The only case where it might be relevant is if one was trying to run ultra-tight quench.
so with the smaller cam but more comp it should be around the 550hp zone. Still a tough ls1 stock stroke engine.
