Help! No oil pressure!
The Melling pump came with two o-rings - one black and one green (thicker). The pickup came with one green o-ring which is about the same thickness as the Melling black o-ring. Based on the instruction sheet that came with the pump, black is the correct one for the pickup I have.
The original pickup came with a blue o-ring. The original pan and pickup I had purchased some time ago before I rebuilt the engine. It was a genuine GM pan, so I am surprised it didn't have the correct o-ring????
Anyway, I'm hoping this is the problem. I can't find anything else to blame........
I'm in the process of priming the oil system using a fertilizer sprayer pump as described in various posts and Youtube videos. Basically you connect the fertilizer sprayer pump to the oil port on the side of the block using a barb adapter and fill the sprayer with a quart or so of engine oil, pressurise it, and pump the oil into the engine to force air out of the oil galleries, etc. while at the same time filling it with the oil. I started by removing the oil pressure sender, pressuring the sprayer pump and making sure oil is flowing out of the sender port before reinstalling the sender. That part worked fine.
Next I checked to make sure oil is coming out the tops of the pushrods and flowing down the rockers. This part didn't work so fine. There are about 5 or 6 pushrods where I can't see any oil coming out. I've tried turning the crankshaft pulley as shown in the videos but still no oil from those pushrods. Here is the procedure I'm using:
1. Pressurise the pump
2. Wait for oil to come out of one or two pushrodes on each side of the engine.
3. Turn the crankshaft pulley two full revolutions.
4. Repeat steps one and two.
5. Turn the crankshaft pulley two revolutions plus 90 degrees.
6. Repeat steps one and two.
7. Repeat steps 5 and 6 two more times, each time adding 90 degrees to the turns.
I never seem to get any oil out of 3 pushrods on each side of the engine (5 out of the 8 have oil on each side). A couple of the pushrods seem to have oil flowing regardless of the position of the crankshaft?
Is this a problem? When I get everything back together again, and start the engine, is it likely the oil pump will "force" oil up those troublesome pushrods?
Cheers,
Greg
PS> I've loosened the bolts holding the rockers as suggested in one of the videos - the idea is to relieve the pressure on the lifters, so they will get 'pumped up' with oil during the priming procedure. I didn't fully back the bolts off, they're firm enough to keep the rockers in place and also keep the pushrods firm against the lifters without pressing down on them too much. I'll re-torque them once I finish priming.
The lifters areLS7 High Performance Roller Lifters For LS1 LS2 LS3 L98 Holden Chevy from ATP Autoparts. (no sure of the brand). I read somewhere that lifters come out of one of two factories worldwide, so I wasn't so concerned about brand names when I purchased them.
Not having anything else to go on, I'm assuming at this stage that the o-ring on the previous pickup not being a tight fit was the issue with the supply side. (or else an old worn oil pump which was still the original)
Next step is to put it all back together and get it out on the road and see how it goes. Before I do that I need to re-route the transmission cooler lines. The new oil pan seems to be wider than the previous one, and the space between the oil filter and exhaust is now very narrow, meaning the transmission cooler lines are resting against the exhaust - not a very desirable situation!
Regarding the issue I found when priming the oil system with my sprayer pump, I can only assume the pump did not have enough pressure to get oil through all the pushrods at the same time, or the tube I used to connect the pump to the port on the block was not wide enough - I used a 1/4" ID tube but maybe it needed to be 3/8".
Greg
I'm at a total loss! I've replaced the oil pump, oil pan, pickup and o-ring. What else could it be? Maybe a hairline crack in the block or one of the heads which opens up when the engine is hot. But I would expect to see oil in the coolant or coolant in the oil if that was the case. Both the oil and coolant look fine.
When I had the pan off I checked for any 'walking' bearing on both the camshaft and crankshaft, but couldn't see any.
Any ideas, anyone?
Any ideas, anyone?
Were there any other indicators your oil pressure was truly that low?
Sorry if some of this was asked before I didn't reread the entire thread.
As I mentioned in an earlier post, I've checked the dash gauge against the reading from the PCM. The PCM is about 10psi higher. So when the dash gauge reads 0, the PCM is reading 10. If I give it some throttle, the pressure increases. by about 10~20 psi on both the dash gauge and the PCM.
If I let the engine idle for a while, the PCM goes down to 2 psi and the dash gauge actually goes below the 0 mark.
I'm pretty sure the sender for the dash gauge is not showing an accurate reading. I intend to replace it. Also, not sure if the hex riser is causing the pressure readings to be inaccurate?
I would expect the oil pressure to go down as the oil temperature increases - the viscosity of the oil will decrease as temp rises. However, minimum oil pressure for an LS1 is about 7 psi I've read in other posts. My oil pressure is going down to 2~3 psi when the engine is hot.
I've had ongoing issues with engine temp. The temperature of the coolant is getting up to 220~225 deg. F after running for around 10 mins. Then the fans kick in and temp drops about 10 deg. I've read these temperatures are not unusual for an LS1. Could it be that at these high temps it makes the viscosity of the oil so low that the pressure drops to these low levels? (really grasping at straws here, but I am totally out of ideas!!!).
The issue is temperature related as when the engine is cold I have good oil pressure (around 40psi). Its when it gets hot the trouble starts. As you say, could be a crack in an oil gallery that opens up when the engine gets hot. How would I check for this?
My Gen V build used a Holley pan and the stock 5.3 dipstick/tube, which showed full when actually down 2 quarts...
The issue is temperature related as when the engine is cold I have good oil pressure (around 40psi). It’s when it gets hot the trouble starts. As you say, could be a crack in an oil gallery that opens up when the engine gets hot. How would I check for this?
