Help! No oil pressure!
I suspected the second sender was faulty, and I confirmed it by measuring the resistance which should be around 240 ohms at 0 psi. It was reading 1500 ohms with no pressure applied so I knew it was faulty. I was checking the value on the dash gauge against the reading from the PCM and there was always a discrepency of around 10 psi, sometimes greater especially when the engine was hot. This is explained by the faulty sender connected to the dash gauge.
So not being able to trust the reading on the dash gauge, I was going by the reading from the PCM. The oil pressure reading from the PCM seemed to be valid, as it started at 40psi when the engine was cold, and then started dropping as the engine (and the oil) warmed up. The reading seemed to be ok for about the first ten minutes of running (it went down to around 20 psi). But it kept dropping until it got down to around 3~4 psi. As I had no reason to suspect the sender was the problem, I assumed the oil pressure had actually dropped to that level.
After I replaced the factory oil pressure sender with a new one, I ran the engine again. It started at around 40 psi when cold, and after about ten minutes of running it got down to about 20 psi as before, but it dropped very little after that. After about another 5 minutes, it levelled off at 18.5 psi and stayed there. I ran the engine for another 20 minutes and it stayed steady at 18.5 psi. (of couse when I hit the accelerator it goes up to expected levels)
I had two faulty oil pressure senders! What are the odds? The fact that the original sender showed valid reading for the first 10~15 minutes of running and then decided to go faulty I can't explain. Unless it has some strange fault related to heat, or the fact that the hot oil inside it causes the fault.
The only thing left to figure out is a slight 'ticking' noise I get at the front of the engine. I suspect there is not enough oil getting up the pushrods at the front of the engine (I noticed this when priming the oil pump when I installed it). Maybe a differenct grade oil may help? (I've got 10W-40 in there at the moment).
I wasn't looking forward to pulling the engine out again. (it a real pain in the butt to get out and get back in again!). Hopefully, I won't have any more issues with lack of oil pressure. Anyway, I replaced the oil pump which probably needed doing, and installed the F-body pan which also needed doing as the truck pan I had on there didn't have a lot of ground clearance.
Thanks for everyone's comments. Helped me eliminate things which it wasn't.
Had anyone mentioned verifying with a mechanical guage?
I once did a compression check on my truck, and somehow the little adapter was left in the last spark plug hole. I screwed the spark plug into the adapter without realizing it. It was months by time I realized it, only because I noticed the adapter missing from the kit!
However, probably a thicker oil would be harder to 'push' up the pushrods, I'll switch to 5W-30 and see how that goes.
