Compression Questions
can build for natural aspirated now but keep in mind ring gap will be different for boost than na.
Or gap it enough now and use a small combustion chamber now to get compression. Change heads when you get boost.
Don't be afraid of some compression. Everybody loves to forget that a STOCK LS2 came from the factory with 11.1:1cr! That's a factory engine that You can run on 87 octane for its entire life without breaking it.
People boost the LS2 all the time with excellent results. The more compression you start with, the more power you'll make. You're going to have to tune it regardless so You're just leaving power on the table going with the lower compression ratio. 11.55 is nothing to worry about. My current combo maths out to 11.9:1 and my Cam closes the intake valve at 76° @0.006" so I can daily drive it year round in St. Louis with zero issue. Works just fine on 87 octane however I Go with 91-93 usually as the exhaust smell is less offensive sitting in traffic with the more expensive gas though there is really no measurable difference in power or drivability between fuel grades.
The factory ignition system is so much more accurate than the old stuff that the added compression is absolutely no trouble at all because the PCM is able to much more accurately control the timing at lower speeds than any old distributor. Even if you did get some spark knock, The PCM would pull timing until you were able to adjust the tune to compensate. Timing is efficiency and often less is more, so again the more compression you start with the less timing and boost you'll need to make the same power if you decide to add it later on down the road.
You seem to know this but the LS1 and LS6 engines can't be overbored more than a small hone, like 5-10 thou. This is an option to get a fresh bore, and pistons are available, just keep this in mind. That piston will probably be how you chose your compression ratio as well.
The 4.0" stroke crank in a stock length cylinder sleeve LS1 or LS6 block can cause more than acceptable piston rock. Its also very expensive not just in the crank but in other things like oil pan and given the choice between that extra stroke or spending extra on the intake/heads/exhaust/tune I would chose to spend money on the top end as I think that would gain more power. If you are worried about strength the stock 3.66" crank is very strong, capable of over 1000hp, the weak point is the stock piston followed by the stock rod. The most popular option is to replace pistons and keep the rods if under 7000rpm.
Maximize fun, even if it's at the cost of maximum horsepower.
Good to hear that. The compression #'s made me nervous because the 67 GTO was a 421ci bored .30 over with wedge pistons to 12.0:1 and if I didn't run 104 octane, it pinged like no tomorrow. I am just getting in to the Hp tuner thing, I have a long way to go before I get it completely, but its making sense to me. I have a stock 2021 RS LT-1 Camaro and its got a 6.2L that I believe is 11.0:1. But then I was on a hot rod thread and they were insisting on no more than 10.0:1 with boost otherwise you need octane boost or meth to run pump gas. I am sure they were talking SBC motors.
If I do this right my trans am stroker should smoke my newer camaro!!
With boost, you will be limited by fuel octane with that high of compression. You will want e85 or race gas if you want more than 10psi boost because you will have to retard the timing very low and it will not be optimal. That being said, 10 pounds of boost on a high compression engine like what you are planning will make alot of power!
I honestly would just sell the LS1, and put your money into a different block. The 383 you are planning adds a ton of money to the build for not much gains. I personally would look for an aluminum 5.3. gen 4. Stock they will handle all sorts of power compared to a stock LS1.
For what you are doing you DO NOT need a fancy forged engine. The bottom end in these engines in stock form are good for tons of rpm and horsepower with proper valvetrain. I really wish I didn't sink so much money into the bottom end of my engine, because I could be doing everything I am currently doing and more with stock pistons, rods, etc.
Not to derail the thread, but one very critical piece that I do not see you mentioning is the transmission behind this engine. Whether it is a 4l60 or a t56, you will want to look into upgrades there.
In my experience you'll want a little bigger stall than that. Try 3200-3400. Do not get a cheap converter! Dollars spent is directly proportional to performance when it comes to torque converters.
I don't play with 4l60e's anymore. They just don't survive. I tore up my very built one(only things missing were billet input and Sonnax smart drum) in less than 4000 miles. I am very abusive to my car though. If you drive like a more reasonable human an upgraded 4l60 will probably be ok. For way less money I have a much stronger 4l80e. If there is forced induction in the future do not waste your time or money on the 4l60e. Just my experience.
On top of that I’d suggest not using an LS1 block. Why spend money to an anemic block build? I’d look at 4” bore motors if you are building a monster. You can use most of your ls1 parts… Or IMO most are better off building an alum 5.3 or even a 4.8. They have much more meat between the cyls, ability to overbore, better deck surface, etc etc. The alum 5.3 is also a siamese block and likely one of the strongest OEM blocks out there.
Comes down to what your power goal is ultimately. Then using the best parts for the least amount of money to get you there. IMHO 383 LS1 with big compression and boost isn’t the way to do that. You don’t need cubes to make power with boost. In most cases for a street/strip setup you are better off with a motor that makes LESS power at low RPM. Other wise when you add boost it will just blow the tires off…. Then you are pulling power to plant the tire. You 100% don’t need an 11:1+ 383 to make a street strip 700-1000ish crank HP turbo small block. Its an expensive, impractical, and poor choice for most IMO. Basically the exact opposite of an NA build.
Just my .02.
My personal experience testing the limits with these things are limited to naturally aspirated combos where I've tried smaller or shorter cams with earlier intake valve closure trying to find the limits of DCR at lower RPM under load on pump gas and when you get it right it makes a big difference in throttle response and transient torque for a given combo so I thought it would help with low speed response and turbo lagging when more cam overlap is used
Back to the basics I think I get it. I can sometimes forget the longblock engine is simply just an air pump on its own but then if you add the boost The smaller combustion chamber becomes physically less effective inside the engine for a given fuel as the boost pressure and engine speed coincide where the volume of the air over the piston would be matched to the intake manifold pressure. Think about it like cc'ing the combustion chamber on the heads with a pipette of fuel instead of water or oil haha
