Help Identifying Bolt Hole
Old Dec 29, 2023 | 05:05 PM
blt91RS's Avatar
Default Help Identifying Bolt Hole
I’m in the process of putting a 5.3 back together in an s10 swap I’m working on. I cannot figure out what goes into the bolt hole pictured. It is at the back of the valley cover on the passenger side next to the cam position sensor.
Thanks
Old Dec 29, 2023 | 07:57 PM
It was used as a grounding location originally from the factory.
Old Dec 29, 2023 | 09:16 PM
01CamaroSSTx's Avatar
I made the mistake of not tightening that bolt down after a 5.3 swap in our 05 Tahoe and ended up having connectivity issues with DBW. It was kind of a PITA to reach once everything was back together and in the vehicle. I've found that working on trucks is not something I'm fond of.
Old Dec 29, 2023 | 10:22 PM
Kawboom's Avatar
As someone who has identified many bolts, many threaded and unthreaded holes, and many bolt holes, I can say 100% confidence that is a bolt hole.
Old Dec 29, 2023 | 11:04 PM
I know where you're going with this so lets be clear. Yes that is a bolt hole and I do know the difference.
Old Dec 29, 2023 | 11:10 PM
dixiebandit69's Avatar
It's a ground wire hole.
Years ago, I had a customer with an '06 Suburban with a DBW problem that would send it into Limp mode; it would NEVER do it when he brought it into the shop, and I replaced EVERY part of that system, and ran continuity/ shorting checks on every single wire. Everything checked out good, and he still had problems.
That ground was the problem.
Never again.
