I have a 408 engine with lunati rods crank n cp pistons. Upon assembly I noticed the crank flange was taller which I didn't know until I installed the rear cover. Who makes a flat sfi flexplate for tall crank flange for a 4l80e trans with a converter that has 3 bolts instead of 6
You have a Lunati crank that has a longer flange than standard? I must say I’ve never seen an aftermarket crank with the long flange. If no one posts up to help, I’ll move this over to Automatic Tranny section.
Yes I do! I found that odd to begin with Here you go
