5.3 terrible performance
Old Jan 7, 2024 | 05:22 PM
elg180's Avatar
Default 5.3 terrible performance
Gen 3 5.3
all new internals all forged
forged +2.9 pistons (mistake, i realize they are dished)
243 heads, stock machining aside from .010 over exh
Tbss intake
Holley 100lb injectors
BTR stage 2 turbo truck cam
long tubes
CAI
double valve springs
roller lifters
Stock 342 gears
Stock height tires
2wd
​​​​87 mm tb
Professional tune
​​​2200 stall converter
4l80 trans
Will install terminator x and 7876 turbo once it runs ok
Truck has less hp than stock. Extremely lazy off line. Starts to come to life above 3500 but expectations are very low due to lazy take off.
Tuner told me something about not being able to get low end timing to stay. Told me to get term x. I know ppl run stock ecm with far more than i have.
Any ideas why this truck is so bad? Stock 1500 2wd will smoke it
i know compression is low already. Its missing more than the 10 hp another compression point would add.
Ideas please!
Old Jan 7, 2024 | 05:44 PM
Scarebird's Avatar
Where is the turbo?
This is a pretty big cam, lotta injector - sounds like this is the classic too much for the displacement.
Old Jan 7, 2024 | 05:46 PM
elg180's Avatar
I havent installed turbo yet. I will once i get na running right. The large injectors and fuel pump are for anticipated turbo install.
I made a mistake on earlier post. Its a stage 1
​stick, .222/222 .598ish.
Old Jan 7, 2024 | 06:53 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I am assuming you originally had a 4l60, since you refer to what the truck felt like stock with a 5.3. This means you went from a 3.06 first gear ratio to a 4l80 with a 2.48 ratio. You also added over 80lbs of transmission weight. This alone would make a stock motor much slower off the line. However, you now have a higher performance cam, which also makes less power at off-idle rpm ranges. You say you also dropped compression, so there is additional off idle power lost. You kept the stock rear end gear, so that is not helping you regain any torque to the wheels like a steeper 3.73 or 4.10 would. You mention a 2200 stall speed, which is almost stock, so no help there. Bottom line is you need a steeper rear end gear and higher stall converter to keep the truck from being an absolute dog off the line. And fire your tuner if he does not know how to achieve desired timing on a factory ecu.
Old Jan 7, 2024 | 06:54 PM
LilJayV10's Avatar
Post a log and tune.
How are we supposed to give any decent advice?
The internet jockeys will be in here shortly to give a list of reasons based off nothing.
A log and a tune...
Old Jan 7, 2024 | 07:03 PM
elg180's Avatar
Thanks folks, ill see about getting data from tuner to post.
Another tuner told me a lazy tuner suggest terminator x right off the bat. I do get feeling hes brushing me off bc his business is more high end cars.
Reason for this question is so i could get my S together before o go pay another several hundred for a tune.
additiong the final drive to high rear gear are definitely not ideal. Just didn't expect so much. Wont even spin tire in brake stand. Its awful
Old Jan 7, 2024 | 07:11 PM
LilJayV10's Avatar
How much does it make, do you have a dyno graph?
and that's not a big cam.
elg180's Avatar
I also want to add another bit of info. Seems super rich. Getting ~8mpg abd truck wont start on first crank. Have to turn key off and then start. Acts like its priming or something occasional farting and popping on highway if i get off and back in gas
Old Jan 7, 2024 | 07:58 PM
elg180's Avatar
When i first built engine it was mated to a 4l60e with 3100 converter. It was around 300 hp at wheels on 2nd gear pull. Tuner didn't go 3rd. Mentioned fear of 2 pc driveshaft....
4l60e fried and did segment swap to 4l80. Tuner touched up and now its crap.
Need someone new in orlando area. Mostly Import guys everywhere
Old Jan 7, 2024 | 09:41 PM
Personally, I’d go ahead and go Holley electronics AND the turbo now, and re-tune. I know an excellent Holley tuner that remotely tunes. He will get that truck running superbly, with or without the turbo in place. You’ll be glad you did.
Old Jan 7, 2024 | 10:34 PM
gametech's Avatar
The 2nd gear pull is somewhat common on those trucks. The factory speed limiters are set to 98mph on them, so driveshaft critical speed is never an issue in factory trim. With the limiter removed, they are definitely capable of enough speed to cause serious, and possibly catastrophic damage when spun up too high. I did the math just out of curiosity, and you would have to go even deeper than 4.10 rear gears to equal the same total gear reduction with first gear in the 4l80 that you had with the 4l60, so it is a huge difference. That is close to a 19% difference in seat of the pants take-off torque to the wheels.
Old Jan 7, 2024 | 10:40 PM
elg180's Avatar
this is very good information. I was not looking at this as much as power output of engine. It makes complete sense now. I was unaware of how much different the 4l60e was. Thank you
Old Jan 7, 2024 | 10:42 PM
elg180's Avatar
If you want to share info id be up to try. Im convinced my issues are primarily final drive and gearing. Ill probably go to 4 10s, install turbo and terminator then retune.
Old Jan 8, 2024 | 12:11 PM
Sure thing. Here’s a link to his personal info page here on Tech. He worked for Holley for a while. Seriously considered the best Holley tuner anywhere.
https://ls1tech.com/forums/member.php?u=10881
Old Jan 8, 2024 | 12:57 PM
elg180's Avatar
Awesome, thank you
Old Jan 8, 2024 | 01:26 PM
RB04Av's Avatar
Low compression for N/A
Injectors are ridiculously too big (about 4 times stock size)
Terrible gears
Poor cam choice (for N/A, that is)
Not enough converter (nowhere close)
This is why you build EITHER a turbo motor, OR a N/A one. Your combo might be appropriate for a turbo; I'm not going to try to argue that one way or the other; but it's ABSOLUTELY BASS ACKWARDS for N/A.
All the talk about gears vs 4L80E is spot on. The 80 is much closer ratio than the 60, therefore needs more rear gear for the same "leave", all else being equal.
Old Jan 8, 2024 | 01:39 PM
TrendSetter's Avatar
im in mims east of orlando. have a 2wd hub dyno and will tune p01/p59 or any standalone.
Old Jan 8, 2024 | 03:13 PM
Fast355's Avatar
I noticed very little difference in leave after swapping to a 4L85E and the 85E was quicker to 60 mph. Makes me wonder if the tuner has the 4L80E segment in place and it is even getting 1st gear.
Old Jan 10, 2024 | 09:24 AM
grinder11's Avatar
The 4L80E is also a less efficient transmission that the 4L60E. It's much more durable, but not as efficient. Takes more power at the input shaft to equal the same power at the output shaft as the 4L60E. FWIW.......
Old Jan 23, 2024 | 06:24 AM
jasons69chevelle's Avatar
2200 stall seems like it would be a bad choice.
