2004 lq4 mid year engine head bolts.
Its a mid year 2004 lq4 from an express.
I'm assuming the bolt length difference is in the block not the heads?
One bolt kit does 1 side. 1 has 2 shorter bolts and 8 long
The other has 10 long.
Which bolt holes are the short ones if it is in the block?
So the top outer are shorter. Any idea how much?
I guess it doesn't matter. Any shorter means shorter means older bolt kit.
03shows the kit with 2 short 8 long.
05 shows 10 long.
04 express vans show both kits available.
Measuring the blocks bolt holes I have determined mine are all the same length. So 2nd kit.
Early are (2) M11 x 2 x 100, (8) M11 x 2 x 155
Late are (10) M11 x 2 x 100
As per Summit data sheets
I switched them.
So a question then.
Wouldn't the shorter ones work on all years? If there's no change with the head. Then it shouldn't matter?
The bolts don't bottom out in the block even with stretch fit, so the number of threads below the bolt shouldn't matter. If it's the newer block or the older design the short bolt still threads in the same number of threads.
Regardless. Mine are all the same length so I need the 2nd design bolts.
Both bolt sets list for the 2004.
