Horribly noisy top end!! Video attached
To start with, I put my phone right next to the headers and intake so the mic really makes it pronounced. With that said, it is really loud! Is it normal for a high lift cam?
I've owned the car/engine for 5 years and have always thought it was very loud, I guess I'm just now getting concerned. It also uses oil, but I beat the hell out of it and read LS1's use oil when abused? The engine was professionally built and has about 7K miles on it. Its mainly an around the town toy is why the miles are so low.
Oil analysis attached, but the engine is newer so it might not mean anything.
Video is too big so I have to link it to YouTube.
1966 Chevelle with a 2002 Camaro SS LS1 Engine
5.7 LS1
243 Heads
• 2.04 Intake Valves
• 1.575 Exhaust Valves
• CNC Ported
• 10.7:1 Compression Ratio
• ENGINE PRO 07-13702-16 CHEVY GM LS ROCKER ARM BRONZE BUSHING TRUNION KIT WITH BOLTS
HA2148 Roller Lifters
Engine PRO Push rods 581-7400 LS1 .083
2500300 Trick Flow® Track Max® Pacaloy Valve Spring and Retainer Kits
LS6 Intake
42 LB/HR PERFORMANCE FUEL INJECTORS
Wiseco Pro Tru Street Pistons PTS523A903 (10.7:1)
Custom grind cam .627 Lift in/ex
LT Headers
5.7 LS1
243 Heads
• CNC Ported
LS6 Intake
LT Headers
5.7 LS1
243 Heads
• CNC Ported
LS6 Intake
LT Headers
5.7 LS1
243 Heads
• CNC Ported
LS6 Intake
LT Headers
But seeing how it's both sides I doubt it's fuel injectors. I'd check the rockers without the covers on and see if it gets even louder.
Did you check these items when building the engine:
- piston to valve clearance, especially with cams over .600" lift
- pushrod length checked?
Never knew a parts company called Engine Pro existed, after a search found out that they're from the Netherlands.
https://www.wilminkperformance.com/en/contact
I just stick with parts that have been tried and tested, SRP, ARP, Melling, Comp to name a few from authorized distributors and Summit. The Ebay and Amazon s#*t is not worth it.
The following users liked this post:
G Atsma (01-14-2024)
Valves can make quite a bit of noise as they're closing on the seats, especially through aftermarket headers but that sounds excessive and you'll need to pull the valve covers to inspect everything. Could have a clearance issue with the rocker arms and the valve covers which I doubt but it needs to be checked and pay attention to the rocker arms and their relationship with the spring retainers as the valves open and close as well as the bolts that fasten the rocker arm to the head. I read somewere that a guy had the allen style bolts making contact with the rocker arm during its travel so look for that as well. Another thing it could be is improper lifter preload. Make sure you have proper pushrod length and that your getting enough preload on the lifters. Good luck with it and hopefully you get it resolved soon.
