5.3 swap msd 6014 engine "dieseling" help!!
Old Feb 20, 2024 | 09:16 AM
Troymatthews96_'s Avatar
Default 5.3 swap msd 6014 engine "dieseling" help!!
hello all, i have a 1985 k10 that i have ls swapped with a 5.3 ran by a msd 6014 box, engine will not shut off after ignition is switched off, i believe it is not an electrical issue because i pull the battery cables off and it still stutters when i shut off. scratching my head on this. any help is appreciated
Old Feb 20, 2024 | 10:39 AM
Hot spot in chamber.
You must be carbureted, as EFI doesn't allow dieseling due to fuel being shut off.
If you can decrease the idle a bit it might help.
Old Feb 20, 2024 | 10:48 AM
yes it is carbureted, edelbrock 600
Old Jun 4, 2024 | 12:59 PM
Gregc901's Avatar
Default Same issue
Did turning down the idle fix your problem
Old Jun 4, 2024 | 01:04 PM
Gregc901's Avatar
Default 1980 ls 5.3 swap with msd 6014
Also noticed that gas was in oil … was thinking that it was due to elbrock electric fuel pump over send gas to carb. It’s measured at 5-6psi on fuel pump… but it’s turn off at ignition switch! Hope it’s not a piston ring. I can deal with a vale stem seal. Any suggestions! Other than going completely efi?
