I'd say odds are very good that your, or my, mental stopwatch isn't too accurate when splitting 10ths of seconds!! But you're probably like me and many others around here, in that after putting together new engines and components, it's only natural to hear sounds that were probably there before. But now they're "louder!" Or think oil pressure takes a half second longer to build. Could be old gauge, different gauge, different sender, or you, whatever. Your numbers are good. Gas it!!! Nothing wrong with GENUINE GM LS7 lifters. I have run them for 10 years/52,000 miles on a .600"+ lift, 232°/250° cam, dual PAC springs (also 52,000 miles on them) with 165lbs seat, 425lbs open. I will say there's not the insurance, or abuse tolerance with them that you'll get with good Johnsons. Up to 7,000-7,300rpm, they're good lifters for the $$$. Start running over 7,500rpm for extended periods in HPDE's, or miss a gear and overrev, and they may not hold up. My .02....
