243 vs 5.3 heads
Curious why you say the 243's have more potential? I'd argue that the 706's have more potential, esp. per $. You are starting out with a dirt cheap head and can easily add a larger intake valve AND do a performance valve job and port cleanup done to them for roughly the same cost as the 243/799 untouched.
There is much more meat on the smaller 706 ports/runners. So they can be shaped into a race port more easily. On the 243/799, they have to remove and add material to to get the ports shaped ideally. Head porters I've spoke with prefer the 706's for that reason.
I'm not saying 706's (esp. in their stock form) are some perfect BA race heard. They are far form it. But the 243/799 is VERY overrated IMO and not a worthwhile upgrade for guys with under 470chp or so NA.
243/799 def flowed more and had larger runners, no argument there. They just don't perform as well due to the larger CC. If you were to mill a 243/799 to 61cc they would def out perform the 706's easily. But Then you've lost a lot of deck strength and spent what amounts to entry level aftermarket head prices. Esp. if you choose to port and work the head any beyond milling. You can easily be into a set of milled/ported 243's for more than the cost of the entry level aftermarket heads with much thicker decks that flow better. So I guess my point is the small chamber stuff has the best bang for your buck on super mild NA builds around 400-470chp. And if you want a performance head, you'd be be better off buying aftermarket than modifying the 799/243.
i was thinking of going to flat top pistons, 317 heads, and a smaller cam as I spend 99% of my time below 3000 rpm.
As is, it’s only slightly better than the 5.3 LM7 I pulled out below 3000.
