408 stroker cam recommendations and ring gap
Iron block 6.0
11.1:1 compression
trickflow 215 heads (I know they are probably a bit on the small side for a 408 but they were free with the car)
Fast LSXR 92 intake
Engine is going into my 05' CTSV, looking to hopefully make 500hp
This car will not be a daily driver more of a fun weekend street car.
I am not a expert by any means at picking cams, currently I am between the BTR stage 4 NA 233/248 .630"/.615" 111.5+2.5 and the BTR 400+NA CAMSHAFT V2 236/25X, .636"/.636", 114 LSA but unsure which is the best one to use.
Also am looking for advice on ring end gap I plan to run this engine NA its entire life, I currently have the the gaps set to 0.020" on the top ring and 0.023" on the second ring. just wondering if this was enough gap or if I should go more?
Iron block 6.0
11.1:1 compression
Fast LSXR 92 intake
~238*/246* 114*+2* .621"/.604"
should easily make 600 @ crank & ~ 500 wheel (manual trans)
with a good exhaust no need for more than +8* exhaust split,
will tune and drive great.
My .02
