Springs for boosting an L33 stock cam around ~15 PSI?
I'm in the process of building a 5.3 L33 for boost. I'm running the stock cam as I am using a 6 speed standard and don't require a longer power band.
I plan on running around 15 psi of boost, what springs should so upgrade too?
SURE, the Exhaust Pressure (EMAP) can OPEN the exhaust valve on the Intake Stroke, not good.
The 130# seat pressure will keep BOTH valves on the seat @ 15 psi/MAP/ 30 psi/EMAP.
This spring has lower nose pressure, good for your stock valve train (longer life)
