408 stroker heads?
The heads flow 312 cfm and should easily make over 600 H/P. It just depends on where you want to go.
First choice, money no object Mamo Motor Sports 235's & Ported Fast 102
Second choice AFR LS3's, Ported OE LS3 Intake
Third choice Ported Fast 102 will be needed to max out your 215's w/ at least 238/246 cam, 1 7/8" LTs
with 3" exhaust to "max out" for a street able set up.
By further porting heads while off, will save you labor, down time and money. Intake is on top and easily swappable later on.
