Stripped cam retaining plate screws
A cutoff wheel and "V" shaped cuts beside the head just close to being thru the plate.
A chisel in the cut will crack the plate.
Knock the piece out from under the head,
Remove the plate.
On the weld/nut deal.... Not enough heat.
Have to use care to start the weld puddle on the bolt and not on the nut.
Remove the plate.
Remove the plate.
Remove the plate.
Ive watched videos on how to use it, everybody contradicts each other on what to do, what valve to shut off first, etc. So i just put it off to the side.
Personally, I'd avoid cutting into that plate!! If you make a mistake judging how deep you are, youll be cutting an oil trench into the block!!! With my luck, I'd be scared to try it.....
Not really many options ATP. im going to continue using the screw extractor with the LHBs. havent been able to get to working on this damned thrust plate recently.
Screw the plate! It's being replaced anyway so drill the heads of the bolts off and remove the cover. After that you'll be able to weld nuts to what's left of the bolts and wrench them out.
@66OldsLS How did you make out with those damn retainer plate screws? FWIW, I followed the advice from the forum on the Mahle cam retainer plate. They are the original style with regular hex head cap screws. It fits fine, and I have no interference with the timing gear. I suspect GM went to the flat head design to clear some of the DOD timing gears, and just went with it for all the LS engines, DOD or not......
I was skeptical about drilling the screw heads. Because there's damn little bolt length left sticking out on a flat head screw once the heads are gone. My welder used the biggest nuts he could still weld on the screw heads. He did this, according to him, because he wanted all the leverage he could get when twisting the nuts. With nothing but a small, short thread to weld to, the leverage will be considerably less.......
ive just started making stress cracks under the plate and going from there. I’ve beat the hell out of the cam journal under the plate that I’ll have to sand out from attempting any kind of progress.
Am I SOL and out of a good oil pressure maintaning block or what do I do?
Are both pics of the same block?? The top pic doesn't look nearly as bad as the bottom one. At this point, IDK what to tell you. The block in the bottom pic has a pretty deep ditch in it, and sure doesn't look good! Where are the threaded holes for the retainer bolts?? With the retaining plate removed, and the timing chain off, be careful about accidentally pushing or bumping the cam towards the back of the block. It can be pushed far enough to fall off the bearing diameters, and that wouldn't be good at all!!!
