05 5.3 head replacement still using factory ecu
Hello. Need some advise. I need to do head gaskets on my 05 5.3. I use the vehicle to tow and is my daily. I need a little more low end power to get up and go while towing. Plus I would like some more power for when I'm off road. What heads can I use other then my factory ones to get some more power and still use my factory tune ecu? Thanks in advance
The ONE thing you could do if nothing else is .040 head gaskets which will give a skosh more compression but more importantly better quench to better avoid preignition.
But that's about it before going further into the engine. Factory tune will still be fine.
First: Towing with a tiny engine? Small motor needs to SPIN. you NEED 4.56 gears. ( that was a period )
Second: Manifold pressure: 10 or 11 PSI should be enough, and will run on 90 octane.
Small engine wants to act BIG, it's going to need some boost. Turbocharger, or Belt drive, take your pick.
While the heads are off, I'd cut them .020", bowl blend the ports, have a good valve job done, use the .040" head gasket, and upgrade the springs.
Like you've heard, 706/ 862 heads are really the best thing for a stockish 5.3. Hell, they're good for up to 6.0, depending on your goals.
