octane question for a daily build
Old Oct 16, 2024 | 08:33 PM
Gen3Convoy's Avatar
Default octane question for a daily build
I am prepping a gen3 5.3, and I was thinking of running gen4 rods and pistons . However, I will be running 706 heads and I believe my compression will be around 10.25:1. I will be running a tsp stage 2 cam, and I wanted to ask if its possible to run 87 octane with the added compression? I know higher compression needs a cooler burning fuel, but this isn't a major build. It is going in an 03 4wd tahoe.
Old Oct 16, 2024 | 08:52 PM
the_merv's Avatar
Veteran: Air Force
Literally comes down to the timing in the tune.
Old Oct 16, 2024 | 09:25 PM
68Formula's Avatar
You should probably keep the PE around lambda .82, especially if you do any towing. Get your quench distance into the .036" to .040" range to improve detonation resistance and run efficiently with reduced ignition timing.
Old Oct 19, 2024 | 09:30 AM
DylanBell's Avatar
All good now?
Old Oct 19, 2024 | 01:18 PM
IGN-1A's Avatar
Default Camshaft Lobe Center
Camshaft Design will help.
A C/L of 116* of greater will reduce compression pressure.
Lance
Old Oct 19, 2024 | 09:24 PM
the_merv's Avatar
Veteran: Air Force
Lower LSA means more overlap and less Dynamic Compression.
Old Oct 20, 2024 | 07:03 AM
Doug G's Avatar
Aluminum heads help since they pull out heat better, but as said...it's all in the tune.
Old Oct 20, 2024 | 03:47 PM
IGN-1A's Avatar
Default -a mixup
OK, 87 + 91 BLEND 70%/30%.
This will GAIN millage AND reduce Knock.
I ALWAYS do this in my LS-92 Escalade fuel tank
Old Oct 20, 2024 | 08:01 PM
I figured you were sporting an Escalade Lance. Good on you sir.
