Valve springs
Additionally, I like the coil bind height of the 19420455 springs (@1.16") better than the earlier style (@1.23") because I have less installed height to work with (Corvair is 1.65" vs. 1.8" stock LS). Even at stock cam lift, it will be close. Maybe I should ask: is there a 1.20" LS beehive spring that has a lower (numerically) coil bind height? My apologies for being such a long and complicated post but I want to try this and hopefully do it right!
https://www.summitracing.com/parts/rsc-pac-1219
if you search by set instead of individual, yes they do show 1.307 dia, so those wont work.
The 1219's are in fact 1.307" There was a typo years ago and everyone has not updated to corre4ct specs yet.
Thanks for highlighting the discrepancy on our site regarding the OD of RSC-PAC-1219. We will correct it to the accurate 1.307" OD.
OP,
To recommend the most suitable spring for your setup, could you provide details on the required install and open pressures, along with the inner and outer diameters of your spring pocket? As a starting point, consider the PAC RSC-PAC-1235-16. We’ve verified the specs below with the PAC catalog. We'll get the coil bind height fixed on our site to reflect the 1.130" height.
Bottom
OD: 1.210"
Top
OD: 1.035"
Pressures and heights
Installed: 135 lbs. at 1.800"
Open: 350 lbs. at 1.200"
Coil Bind: 1.130"
Max lift: .600"
