Cam question for LQ4
Old Dec 1, 2024 | 06:01 PM
paulo6.0's Avatar
Default Cam question for LQ4
I’m currently building a lq4 that’s going to my 03 rcsb sierra. I found a custom grind cam .646 Intake Lift, .631 Exhaust Lift, 297 Intake Dur, 302 Exhaust Dur, 114 lobe separation. is this too aggressive for a 2800 stall for daily driving?
Old Dec 1, 2024 | 06:06 PM
Ls7colorado's Avatar
yes, but the actual specs would be better or cam part number
You really wanna stay under 220 intake duration @ .050 with 112 OR LESS LSA to keep from losing to much low end.
Old Dec 2, 2024 | 05:27 AM
Jake Wade's Avatar
As mentioned, stay below 220 intake duration @.050 for a truck, especially if using it for a truck.
Old Dec 2, 2024 | 07:22 AM
1988montecarloss's Avatar
way too much cam, especially if its still stock comp ratio
Old Dec 10, 2024 | 09:43 AM
gagliano7's Avatar
Also to much lift. That would be rough on stock rockers.
Old Dec 10, 2024 | 04:52 PM
Full Power's Avatar
YES.
Look for a truck cam.
I have a couple heavy rigs with 212/218 .550" lift and they are REALLY good daily driver cams.
Easy to tune, easy to live with, and get BETTER than stock fuel economy, while pulling strong through 6000 rpm.
Old Dec 10, 2024 | 09:28 PM
CattleAc's Avatar
If you haven't bought this yet, definitely walk away from this cam...
All good advice from everyone else who has replied so far.
Old Dec 10, 2024 | 10:27 PM
Abs's Avatar
Abs
are you sure these aren't advertised durations? Honestly its too big even if they are considering the difference is inly 50-60ish.
Old Dec 11, 2024 | 09:18 AM
kinglt-1's Avatar
Yes too big. Go to vendor sites(TSP,BTR,Summit Racing) and search Gen 3 LS truck cams. Holdner has a low buck truck cam for 180.00 that is a clone of the Truck Norris. BTR Hot Rod would be a good cam for a 6.0 in a RCSB. I don't think it would give up nearly as much torque down low if any <3000 rpm as it does in a 5.3. 2800 stall would be a good match.
Old Dec 11, 2024 | 10:08 AM
Abs's Avatar
Abs
I'd suggest a summit 8720 or 8728. Check out those cam specs for a truck.
Old Dec 11, 2024 | 04:55 PM
One post 10 days ago guys…pretty sure that was a prank first post
Old Dec 11, 2024 | 05:40 PM
68Formula's Avatar
Old Dec 12, 2024 | 07:14 AM
Summitracing's Avatar
LS1Tech Sponsor
We were going to make a recommendation, but this seems like a post-and-ghost thread. Hopefully, the OP returns. We shall see.
__________________
800-230-3030
www.SummitRacing.com
Old Dec 12, 2024 | 09:49 AM
Yep. Pretty ridiculous cam for what he had..... he be a TROLL.....
