Swapping springs vs new heads
Other benefits would be I could use new lifters and trays and not risk a lifter and possibly even an engine failure by rolling with 20 year old lifters with 115k miles on them....
New lifters wouldn't be a bad idea, but is WAY more involved
So with that said im doing a Ls3 swap lol, so I dont see a down side to atleast going ahead and doing lifters and throwing a set of nice heads on there while your at it if you have the funds.
Will you be removing your heads to inspect/replace lifters?
I'm guessing it's around 1/10 as much work to swap springs, as it is to swap heads. Not to mention the extra expenses like gaskets, bolts, fluids, etc. etc. etc. As has been hinted at, different body styles make any kind of engine work harder; butt I think you'll find that they have the same effect on either process.
Now if you're swapping the cam, then that ratio goes down to maybe ¼. And if you're swapping lifters, then the heads MUST come off anyway. And of course if the heads are tired and need wirk (valve job for example) then the choice is obviously also already made for you. Butt if you're only "thinking about" a cam swap "in the future", and just wanna upgrade springs NOW, which helps a surprising amount even with a stock cam, then just get out there and do it.
You don't. Just bring the pistons to TDC 2 at a time, fill the 2 cyls with rope through the spark plug holes, and swap the springs out.
I have no reason to think my heads need work. They would only be removed to replqce lifters pro actively. And while they were off, no reason not to upgrade them. It would be the best time.
I wasn't sure if you could use upgraded springs with the stock cam. Didn't know if it would be too much pressure. That's something I might do ahead of time then to make the actual camswap easier if I decide to leave the heads on.
Oh since I'm an old guy (LOL) I put the car up on jack stands so I don't have to bend over so far over the fender. Saves the back.
On mine, when already at tdc, feeding rope into a cyl wasn’t really working. I was well… pushing rope.
also helped because there was hardly any valve movement before the retainer unseated.
OP could make his own adapter out of an old sparkplug. Thats what I did. Just break the porcelin out of the old plug, then drill/tap the plug for either the air hose itself, or a quick disconnect. I used a quick disconnect. I did it myself about 20 years ago. Was the first time I had done it. Lots easier than pulling heads. OTOH, if OP needs new lifters, may as well replace springs on the bench.....
Swapping out springs on a GTO isn't really hard logistically, but changing heads gets a little interesting on the head bolts at the very rear. You have a lot more things to concern yourself with on a head swap like cleaning surfaces, clearing out bolt holes, draining coolant, torques and bolts, etc.
I have a thread on a head swap on LS1GTO which I'm sure you've seen. I did a cam and oil pump and timing chain install along the way. Then when I got it together I found that the springs weren't enough for the cam and had to swap them. I had already done a set of springs on the other GTO so at least I knew what I was doing. The only real trick on spring swaps is having a good springs compressor and keeping track of the lock keepers.
Now maybe the way the LS1 sits in there and the heater hoses are run is different, and the passenger rears aren't that bad to get to, IDK. All I know is I never want to do valves springs in-car again. If I ever get around to an LS swap, all head work is happening BEFORE the engine is in the car.
