Modest Power for my Gen 4 WS6
Old Jan 1, 2025 | 02:07 AM
Usaussie's Avatar
Default Modest Power for my Gen 4 WS6
Hi all, I live in Australia and Ive owned beautiful 99/00 WS6 for 20 yrs, however its engine needs a little work, i.e leaking Hydraulic lifters, rattling Cats and a few oil leaks etc.
Ive decided to use these issues as an opportunity to also boost power conservatively and Im thinking Heads, intake manifold and cam. Ive set a budget of US$2.5-3k
Ive read many sources (incl LS1Tech) that recommend LS6 heads, manifold and cam to be a quick and easy solution to a modest and reliable power increase, however when I go to look (to buy) there are so many options it addles my brain😵‍💫.
Im therefore looking for suggestions (based on personal experience) not only to the approach but to specific brands/suppliers.
Any help will be gratefully appreciated🙏🏼
Old Jan 1, 2025 | 09:08 AM
DUSTYWS6's Avatar
How firm is your budget? I’d stick with stock 243 heads (with new springs that compliment the cam), a stock LS6 intake, and a mild cam. There are alot of costs associated with a tune, gaskets, bolts, fluids, tools that just add up. You can take a look at the cam and spring packages that Texas Speed and Performance offers to get a feel for cost to just do a cam.
Old Jan 1, 2025 | 01:29 PM
Full Power's Avatar
Modest power increase ?
8 PSI manifold pressure will make driving fun.
BOOST is cheaper than engine parts.
Old Jan 1, 2025 | 03:25 PM
LS1 TJ's Avatar
Would a 99 have 243 heads or 241 heads? Same with intake 99 would have a LS1 intake not an LS6 intake?
I would go with a small cam. New push rods and springs. Headers. Good tune. You can still find stock 243 heads and LS6 intakes. I believe Dorman makes a LS6 repo intake. On Engine Masters they tested "econ" LS heads. I think the entry level AFR's was top dog.
Old Jan 1, 2025 | 03:30 PM
68Formula's Avatar
'99 would have 241s and LS1 intake.
Old Jan 2, 2025 | 12:27 AM
Abs's Avatar
Abs
Got a link to this?
Old Jan 2, 2025 | 03:02 PM
LS1 TJ's Avatar
Search Engine Masters on the Motor Trend channel.
Old Jan 2, 2025 | 04:28 PM
Abs's Avatar
Abs
I found this by our buddy Eric Weingartner. He says they flow 272 at .500 I think, but at some point around .530 lift it hit 280 and then came back down. It peaked pretty early and then fell some.
243s on the other hand only flow in the 250s.
Exhaust flow is similar to 243s.
@Rich-L79 knows though that afr doesnt want you using stock rockers with these because they have bronze guides. He got 1.8 ratio rockers and then it rendered the included springs in the heads kinda useless even though his cam was smaller and his calculated lift was under the .600 lift threshold of the springs. He was getting valve float over 6k I think until he changed springs.
That kinda made me not want to mess with these heads. Plus they are over $1300 and you can get TSP ls6 brawler heads or TSP as cast 220s on sale for $1700-1750.
Old Jan 2, 2025 | 08:55 PM
Rich-L79's Avatar
https://youtu.be/jQFu72DzLbk?si=3dczh6-6OFRQ74SR
The problem with the springs had more to do with the cam than the heads. You can buy the AFR heads with upgraded springs which is what I would have done if I'd known ahead of time that I would have needed them. AFR says you can use stock rockers but insist you have to at least do a trunion upgrade on them. Bronze guides do not like any side loading on the guides so whatever you use you need to make sure the wipe pattern on the valve stems is well centered.
Old Jan 2, 2025 | 10:00 PM
Abs's Avatar
Abs
interesting. I could have sworn the rocker thing was because of the guides and I don't think a trunion upgrade changes anything with respect to side loading. Maybe it does help?
Your cam was pretty low lift with non aggressive lobes. Why would that affect the springs when they were duals and good to .600 lift? I thought maybe the 1.8 rockers amplified something and pushed it over the limit, but it never really made sense to me.
Old Jan 2, 2025 | 10:57 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
It was definitely his 1.8 rockers pushing things over the edge. Increasing effective ramp rate, lift, and weight over the valve all at the same time adds up.
Old Jan 2, 2025 | 11:12 PM
Abs's Avatar
Abs
I was considering the following cam kit. The cam has .600 lift on intake and exhaust and the springs are basically PAC 1218s. 130lb seat pressure and 313lb open pressure. Think these would be sufficient with stock rockers (likely with a trunion upgrade)?
Summit Racing SUM-8720-2-BHV Summit Racing Pro LS Camshaft & Spring Kits | Summit Racing
Old Jan 2, 2025 | 11:41 PM
gametech's Avatar
Valvetrain harmonics have too many variables for me to give an opinion unless the parts are just obviously mismatched. That being said, I have only seen one thread on this forum that had a specific complaint about one of Summit's cam/spring combos not being properly matched. It is a long read, but worth the time to search and read it just for the insight into how the issue was handled, if nothing else.
Old Jan 3, 2025 | 12:07 PM
Abs's Avatar
Abs
I read that one. I believe he had an 8707 with .600 lift springs and he couldn't rev out to 7k like the cam description said even though he could with the 8706 cam, which is also 226 on the intake. The guy was very abrasive and had a bad attitude, but @Summitracing handled it very well, answered his questions, and possibly even sent him new springs for free. I forget exactly. I thought it was more than the guy deserved given his belligerence.
I guess I had a similar concern with this cam since it also has a .600 lift. I didn't want to run into similar issues or experience valve float above say 6k rpms.
