help with push rod lenght
Old Jan 6, 2025 | 02:23 PM
learning101's Avatar
Default help with push rod lenght
I have a 2002 5.3 i have rebuilt but i have a question about rod length. i milled the heads .030 off. will i need shorter pushrods 7.400 are whats in it i believe stock. I use the metal head gasket where there is like three sheets of metal. and i dont have a push rod measurer. my best thought was the 7.375. about the closes i can get
Old Jan 6, 2025 | 03:33 PM
Bbknucks's Avatar
The correct answer would be get a checker
Old Jan 6, 2025 | 04:53 PM
Invest in the correct tools to measure. There are a couple of different designs in pushrod length checkers. You need to know the headgasket thickness you used to make this length correct, because there are many different choices of headgasket thickness…which will affect pushrod length. No guessing allowed here…new govt legislation makes guessing at pushrod lengths illegal…and stuff.
Old Jan 7, 2025 | 01:35 AM
KatherineThompson's Avatar
You helped me, Thnak you so much.
Spoiler!
