what lifter to buy
Old Jan 11, 2025 | 05:13 PM
learning101's Avatar
Default what lifter to buy
hey looking at lifters for a 5.3 2002 what is stock or what is recommended? i read some where, ls7 is longer how do i know what are ls7 lifters? i see ls7 in a lot of adds. then i see the word ls7 out front. im looking for stock lifters and also seen these hl124 lifters
Old Jan 11, 2025 | 06:08 PM
LS7 -spec lifters are good for all LS-type engines. They became the default LS lifter when the LS7 came out.
Old Jan 12, 2025 | 04:15 AM
Tuskyz28's Avatar
Caddy lifters are nice but they are pricey
Old Jan 12, 2025 | 06:58 AM
Treburkulosis's Avatar
I agree the LS7 lifters are the way to go. I am running those in my car. The Caddy lifters are nice, but pricey as said above. I would buy a set of LS7 ‘s and call it done.
Old Jan 12, 2025 | 04:02 PM
RB04Av's Avatar
LS7 lifters aren't "longer". They do however have more plunger travel internally than previous ones did.
​​​​​​​how do i know what are ls7 lifters?
Unfortunately you just have to trust the seller. The old adage "if it sounds too good [cheap] to be true it probably is" applies with a vengeance.
Old Jan 12, 2025 | 04:36 PM
garadyy's Avatar
Caddy lifters
Old Jan 13, 2025 | 01:33 PM
Codys89RS's Avatar
I have heard great things about the ls7 lifters. I bought a set and ended up with a knockoff set and chewed apart a motor.
I wish I remember where I bought them but would have to dig through the receipt pile. I accepted it for what it was and rebuilt.
Make sure to go with a reputable seller.
With my new motor we went with a set of comps.
Old Jan 13, 2025 | 02:02 PM
Abs's Avatar
Abs
If you won't spring for caddy lifters, I suggest morel 7717s. Ls7s are different based on the source and personally i wouldnt trust them. If you are going through the trouble of swapping or removing heads, I would put on a better lifter.
