Lm7
I've made ~900 wheel on an early gen 3 engine with the weaker rods that ran like that for several years before I pulled out the whole setup and sold it.
I ran it on E85 with a setup focused on top end power at the sacrifice of peak torque. I don't think it would have survived on pump gas.
I made similar power on a gen 4 aluminum block 5.3 with the stronger rods on pump 93 and water/meth, and that setup was all about making as much torque as possible.
It is a lot easier to trust the engines with the stronger rods, but that doesn't mean you should count out the earlier engines.
LISTEN and Watch for KR, Retard spark until the knock is gone.
cars also arent built by a recipe, you still have to know how to do the work and figure things out for yourself
There are far more cast iron blocks of both the Gen III (LM7 & L59) and Gen IV (LY5, LMG & LMF) persuasions. They all went into light trucks
Among GM LS truck engines, iron block engine production is a multiple of aluminum block engine numbers.
You admit not knowing **** about engines. The same could be said about you not knowing where or how to research LS engine info, especially where it pertains to production numbers.
