Need help asap truck won’t run
Replacing the crank sensor typically means the exhaust manifold has to come off.
As said above I'm not buying into the heads being an issue. Pull the valve covers and see if everything is moving up and down as it should as you crank it with the plugs out.
Yeah when I put everything back together I turned over the motor by hand and could see the rockers/springs working but I suppose I can try that wire idea in the morning HOA don’t like my mini freedom factory at night lol but I will say that the truck won’t stay running even if I use the throttle to hold the blade open (can hear it open and close).
