Need help asap truck won’t run
note: i am NOT saying its properly tuned after that. at all. just that it should start and idle, and then of course you will need to make further adjustments to the fueling and timing to dial it in.
It would be unusual but things work till they don't!
all righty I’ll pull up the logs and adjust some
stuff. Also gunna ensure VATs are turned off to ensure that’s not it.
Like OP, I've also put bigger cams in engines with a factory tune, and they still started and ran.
and yes queef 😭
Replacing the crank sensor typically means the exhaust manifold has to come off.
As said above I'm not buying into the heads being an issue. Pull the valve covers and see if everything is moving up and down as it should as you crank it with the plugs out.
