Yella Terra roller rockers
I would be looking to have 8000 rpm capability just for a split second at a time as I drag race and would not be spending a lot of time up there.
The Gen4 YT is a high quality rocker. I’ve personally only seen one failure, and that was in a road race session at COTA in Texas…which is hard on all parts and tests everything to the 11th degree. Drag racing is the opposite as engines only see redline for 11-12 seconds max, depending on how quick you actually are.
Current block is LS3 but I'm planning a new build although I will stick with a cathedral port top end.
I also had to pull a head off because I dropped a washer down the intake runner. The intake valve was open so it landed on the piston. So I pulled the head. In the process all the pushrods looked great. I even pulled the rockers on the other side and the pushrods looked great. I run Manton pushrods.
