Windage Tray Nuts
Old Mar 10, 2025 | 08:16 AM
upstateNY_Rich's Avatar
Default Windage Tray Nuts
I am not sure if I can re use the windage tray nuts on a LS1 windage tray with the new standard main bolts. I believe they are a flange locking nut M8 1.25 and i would like to replace them I just wanted to make sure that I was getting the correct nuts. I was looking at ARP 300-8312 not sure if they are correct
I found the GM# 11609746 and I ordered HNT-1018-10 Improved racing
Last edited by upstateNY_Rich; Mar 10, 2025 at 12:37 PM. Reason: added part number
Old Mar 10, 2025 | 07:15 PM
dixiebandit69's Avatar
Yes, you can reuse the nuts.
Old Mar 16, 2025 | 03:38 PM
Bob570's Avatar
You can re-use them a couple times I think. Improved Racing has replacement nuts on their website if you want to go that route. They always ship fast too.
Old Mar 17, 2025 | 12:14 PM
thanks, I called Summit and they recommended them and they had them in stock
Old Mar 17, 2025 | 03:15 PM
LS1 TJ's Avatar
I've reused them. Having said that I bet they have them at Ace Hardware. They have a great bolt/nut selection at least in our town.
Old Mar 17, 2025 | 06:05 PM
the_merv's Avatar
Veteran: Air Force
They are stamped to be mechanically self-locking.
Keep that in mind.
Old Mar 17, 2025 | 06:10 PM
The windage tray nuts that ARP supplies with their stud kits are just simple hardware store grade nuts. All they are doing is holding a metal tray up. You can certainly re-use them.
Old Mar 17, 2025 | 06:49 PM
I ended up getting them through Summit, the improved racing nuts
Thanks Rich
 Michael S. Palmer
