Cam choice, advice please..
Old Jan 7, 2003 | 08:08 AM
JoSeY's Avatar
Default Cam choice, advice please..
Ok...I've run into a lil bit of luck here and I'm looking for some input. I've been given the chance to have Comp Cams grind a cam to any spec that I can furnish for them.
Right now the car is all bolt-on's, stock heads, LS1 intake, Mac Headers, True Duals, A4 with 3800 Vig.
I'm looking at a cam along the lines of the Thunder Racing 227/224 114 cam....it's producing some MAJOR numbers with stock heads.
Any input would be appreciated.
Old Jan 7, 2003 | 10:26 AM
Constrictor 98TA's Avatar
Default Re: Cam choice, advice please..
Thunder Racings TR227 is a great cam and alot of people are having great luck with it, but just be warned, if you have Comp custom grind a cam wtih those same specs, there will still be a difference between the two cams since TR uses their own models to achieve higher ramp rates.
If you have Comp use an XE-R grind, it would probably be close, but still not identical to TR's cam.
Either way, if you are getting a good deal on it, I say go for it!
Old Jan 7, 2003 | 08:38 PM
TA_2001's Avatar
Take a look at these installed setups and see
if you can gain any info for your decision.
http://ls1info.com/camstats/showdata.php
