High CR 347 question
Old Aug 3, 2004 | 07:13 AM
Ryan K's Avatar
Pathological Modifier
Why would you waste the $ on a Lunati crank if you are going to keep the stock stroke? That is my question. All you need if you are looking, is a good set of rods, (the longer the better) and a set of custom pistons. As for block work, that depends on the condition of the bores. If you have med/heavy scuffing wou would want the light service bore. and the 3.905 pistons. If the bores are clean, then I would go with a very light hone to resurface the cylinders. Clay the heads and send the mold to a respectable piston company to get a set of pistons exactly the way you want them. Yeah you are paying more for the pistons, but you are saving a ton with staying with the stock crank.
Call me we'll talk about it if you want.
Ryan K.
