High CR 347 question
Old Jul 28, 2004 | 01:35 PM
NataSS Inc's Avatar
Default High CR 347 question
I am looking at making a purchase on some lunati parts since one of the sponsors has some good pricing going on. I want to keep the stock displacement so I am looking at the 347 rotating assy. 12.5:1 combo. My questions are:
1) Will this kit drop right into my stock block or will I have to have some work done?
2) With heads milled .030 will piston to valve clearence be an issue with a 230/227 591/571 112lsa cam using a 1:7 rocker arm?
I am seriously looking into this but am worried about the P2V issue the most. Any input would be greatly appreciated.
TIA
Old Jul 28, 2004 | 03:40 PM
RyanJ's Avatar
SSU Moderator
Depends on the pistons, but the short answer is that Lunati probably makes them two ways, a stock bore, or a 3.905. Either way you will have to get some machine work since you will have new rings, etc. I would bet the PtoV will be fine since the pistons will have cuts in them.
Old Jul 28, 2004 | 03:44 PM
NataSS Inc's Avatar
What kind of machine work are we talking about here? Just getting the cyl. honed out a bit or something a bit more major?
Old Jul 28, 2004 | 04:00 PM
MUSTANGEATER's Avatar
You're looking @ the basic hone and deck stuff. Shouldn't be too expensive. Have you thought about welding the chambers to increse compression ratio?
Old Jul 28, 2004 | 04:07 PM
NataSS Inc's Avatar
I dont think I would want to go any higher than 12.5:1. anything above that and your looking at a straight race gas motor. at 12.5:1 I "should" be able to get away with a 50/50 mix.
Old Jul 28, 2004 | 04:53 PM
jrp's Avatar
jrp
SN95 Director
what compression are you looking to get?
i know scoobie has the lunati kit and he ran some AS 6.0 heads to get the compression down to 11.5 or something and used the TTP equalizer cam 230+ duration. the pistons in the kit are domed 12cc's and have valve reliefs right? are the 2cc's?
Old Jul 28, 2004 | 05:39 PM
With the right setup you could get away with 93 if you know what you're doing. Well at least you MIGHT be able to. Bret@Bauer Racing is really really good at this is helping me set up a high compression Hydraulic roller 347 give me a holler ---->
Old Jul 29, 2004 | 12:14 PM
TTPMatt's Avatar
The 12.5:1 compress ratio pistons are dome tops.. They don't fit well on a lot of applications .We went with 6.0l heads unmilled to fit the pistons. AS makes a strong 6.0l head that will make the power. Scoobie worked out to around 11.3:1 compression with these heads. 93 pump gas.
- Matt
Old Jul 29, 2004 | 12:46 PM
NataSS Inc's Avatar
I may be selling the MTI heads that are on the car now with the milled heads and replacing them with the 225 AFR's. Those should give me the clearence that I need.
Old Jul 29, 2004 | 01:59 PM
RyanJ's Avatar
SSU Moderator
I wouldnt get hung up too much on the static comp ratio (the 12.5:1 you are talking about). your gas will really depend on the cam and the tune. I remember talking to the Colonel a long time ago and on his hyd. 422 he ran like 14:1ish compression, but with the right tune he could drive it on straight 93 and only run like 104 at the track. think dynamic cr.
Old Jul 29, 2004 | 02:05 PM
T/A Medic's Avatar
just remember that if you go with a dome piston they are digitized/designed for a stock Combustion Chamber Design. AFRs have a different CCD... might run into issues with a big dome....
AS has some 6.0L heads being built for me with special valves that make the heads ~61cc without welding or milling. And APE helped me spec out some 6cc dome pistons that make the CR come out to 13.8x
Old Jul 29, 2004 | 09:38 PM
FASTONE's Avatar
Why do you want to keep the stock ci?If you go more stroke say 4.0 with a flat top piston you will have more CR then stock stroke.I'm sure you have a good reason but if you going to buy a new crank seems like extra stroke is free HP!!Just asking????
Old Jul 30, 2004 | 10:24 AM
NataSS Inc's Avatar
Trying to go 200mph on an NA stock inched LS1.
Old Jul 31, 2004 | 03:13 PM
buymeavette's Avatar
i wouldn't really recommend that.......
Old Jul 31, 2004 | 03:31 PM
Scoobie's Avatar
Hey Man, Like Matt and JRP above said i have this set up. Id recommend giving TTP a call. George at TTP built my set up and he used this same kit in his own bottom end build up. For what your looking to do, its a great set up although more costly because of the crank. I would recommend the 6.0 Liter Heads, do the stage 2.5's ! i only did the 2.0's and i put down 437/405 with under 100 miles on the block through the muffler with a **** rear end and clutch. Good luck, and let me know if you have any questions.
-Scoobs
Old Jul 31, 2004 | 09:44 PM
Why is that??????
When done properly there are no problems. Should he mill the **** out of the heads and risk P T V problems and possibly ruin valvetrain geometry?
Old Jul 31, 2004 | 10:27 PM
FASTONE's Avatar
Could you use some slightly milled 5.3 heads to raise the CR ? I think with the Lunati parts the piston is like .020 positve deck ht. with reliefs this should be OK for p to v clearance.I would go no closer then .035 quench though, the pistons may have to be machined down some for this.You could use .010 positive with a .045 head gasket or zero deck ht. and .035 head gasket,all this would help raise the CR. Stock bore and stroke with +7 cc piston dome and .035 gasket and 64 cc head is 12.285,62cc is 12.65,60cc is 13.037
this is 0 piston deck ht.
Old Aug 2, 2004 | 11:29 PM
Why is that??????
i've read that it doesn't make each combustion chamber equal. lots of expenses to go along with this. i read this in ligenfelters book, mainly for race type of deal. just bigger heads, i mean he is buiding the rest up why not dish out the extra cash. i know everyone has there budget but i know not to many people like to burn there cash up.
erik
Old Aug 3, 2004 | 12:15 AM
erik
It's a relatively cheap process and if you go with someone who knows what they are doing it will be fine. Smaller Combustion Chambers are a good thing, I'll give a cookie to whoever answers me why....
I'm sure by Bigger Heads Lingenfelter is talking about Runner ports not CC's of the Combustion Chamber.
Old Aug 3, 2004 | 06:48 AM
have to go back and read it. the books very boring and more of a selling point for him then actual help.
