strange ls oil pressure
Old May 9, 2025 | 03:09 PM
OneRedMarrow12's Avatar
Default strange ls oil pressure
hello i needing help with an strange issue with im having with my 2001 s10 swapped to a 4.8
the issue im having is the motor will have great oil pressure at start up 45psi at 900 rpms
then after either letting it idle for a really long time or a short drive of less than 5 miles my oil pressure will drop to 20 and wont increase with throttle
what makes it strange is that if i stop and turn the truck off then right back on i have good oil pressure again if anyone has any insights into what could be the problem i would greatly apricate it
15w40 oil and a brand new glow shift oil pressure gauge and sender
Old May 9, 2025 | 03:27 PM
Rich-L79's Avatar
Oil is a little thick for an LS engine.
Old May 9, 2025 | 04:43 PM
have had zero issues running it an my other ls motor
and running it for a reason 5w30 is even worse op wise
Old May 9, 2025 | 09:52 PM
Rich-L79's Avatar
If you need heavier oil to keep the oil pressure up you've got bigger problems going on.
Old May 10, 2025 | 06:22 AM
_JB_'s Avatar
I'm betting it's an electric pressure gauge?
Old May 10, 2025 | 08:47 AM
How many miles on the 4.8? 15w40 IS a lot heavier than recommended for an SBE LS. 5W30 usually gets it done.
As said, is your gauge electrical? Check the pressure with a mechanical gauge to be sure. They're more accurate.
Old May 10, 2025 | 10:21 AM
Rick Dorion's Avatar
The fact that you can turn the engine off and then right back on with normal results certainly suggests an electrical gauge glitch.
Anyway, here's a data point: I have two ls engines with 200K miles in my vehicles and both read 40 psi at 600 rpm cold idle, 60-ish at around 2500 rpm. Hot they both are about 5 psi less at the same rpm points.
Old May 10, 2025 | 12:54 PM
this is my 4th oil presusre sensor i cant just keep getting bad sensors 3 gm and 1 glow shift sensor there has to be a mechanical issue brand new rod bearings tho
Old May 10, 2025 | 12:55 PM
brand new gauge and sensor glow shift brand gauge and sensor
Old May 10, 2025 | 04:03 PM
Update
just pulled filter off and cut it open and found filter was fill of glitter and glitter was also leaking out with (filtered) oil most likely either goanna just sell evething or put a 4 cylinder back in made sure to do everything right when replacing rod bearings and obviously this motor hates me and or im a ******* useless idiot who can do anything right
Old May 10, 2025 | 07:03 PM
Originally Posted by OneRedMarrow12
Update
I refuse to listen to your last comment…don’t lie to yourself. Question for you here…on the oil pan, the block off plate for the oil cooler lines…what are you doing at that intersection? What plate is on the pan, with what gasket under it? If that’s wrong there…which is easy to do!…it can cause pressure issues like your having. Any pics of that plate?
Old May 10, 2025 | 07:15 PM
https://www.jegs.com/i/Chevrolet-Per...AaAmCHEALw_wcB
just the factory style cooler block off this same exact one i have linked
Old May 10, 2025 | 10:01 PM
Gotcha. That’s the plate I run on my builds, when no cooler is being used. Now….which gasket are you running with this plate? There’s a 2 hole gasket, and a an open gasket that’s black metal. If you get the gasket wrong..which I’ve seen done before more than once…your bypassing the filter.
Old May 10, 2025 | 10:03 PM
im not sure ill have to check in the morning
Old May 11, 2025 | 06:27 PM
its the 1 hole gasket
Old May 11, 2025 | 06:55 PM
https://www.ebay.com/itm/121850275716
this is the gasket i have for the same block off
Old May 11, 2025 | 07:04 PM
Shouldn’t be any restrictions there.
Old May 11, 2025 | 08:17 PM
im lost then i guess its just time for a new motor as this one doesnt want to keep oil pressure
Old May 11, 2025 | 08:45 PM
Did you rebuild this engine, or is it a pullout buy?
