Too much open spring pressure?
Old May 25, 2025 | 06:36 PM
ramqooo's Avatar
Default Too much open spring pressure?
Have a set of comp cam 26926TS-KIT summit has them listed at 505LBS open pressure while I read on an old forum thread that they are more close to 465LBS but was wondering if stock 317 valves and rocker arms would suffice or should I look into getting some comp cam magnum pro or ultra golds
Old May 26, 2025 | 08:49 PM
DualQuadDave's Avatar
The valves will be fine, those springs were meant as a drop in ls3/l92 so it's not that radical. I would just do a trunnion upgrade and should be fine. I've seen stock rockers handle well over 559+ open pressure. They are 505lbs rate, not total open pressure. The 465lbs open at max lift sounds right given a . 600-.630 lift cam.
Old May 27, 2025 | 08:10 AM
ramqooo's Avatar
Talking
Much appreciated have any trunnion kits you have liked CHE seems to be the most common but know there is BTR and a couple others
Old May 27, 2025 | 08:20 AM
From what I've seen here, CHE is the most favored for quality and functionality.
Old May 27, 2025 | 08:37 AM
MuhThugga's Avatar
Why do you need that much open pressure?
What lifters are you running?
Old May 27, 2025 | 08:39 AM
ramqooo's Avatar
Post
Have both johnson lifter and LS7 lifters think its too much for the LS7?
and its not so much the pressure I need its the max lift that the springs are capable of
Old May 27, 2025 | 10:33 AM
MuhThugga's Avatar
How much lift are you running?
Old May 27, 2025 | 10:43 AM
ramqooo's Avatar
.614 on intake
.624 on exhaust but thats stock ratio rocker arms
Old May 27, 2025 | 12:20 PM
MuhThugga's Avatar
I'd look at using the Summit SUM-174005 beehive spring if you are keeping the factory rocker ratio.
  • Installed Height (in.):1.800 in.
  • Seat Pressure at Installed Height (lbs.):140 lbs.
  • Open Height (in.)(application):1.170 in.
  • Open Pressure (lbs.):350 lbs.
  • Coil Bind Height (in.):1.100 in.
The BTR SP001 valve spring will also work for both the stock 1.7 ratio and the 1.8 ratios, should you choose that path.
  • 155 lbs @ 1.780” Installed pressure / height
  • 380 lbs @ 1.180” Open pressure / height
  • 400 lbs @ 1.130” Open pressure / height
  • Coil bind @ 1.070”
Old May 27, 2025 | 01:04 PM
ramqooo's Avatar
Smile
The reason was due to me getting these for really cheap im talking dirt cheap they were off an LS3 pull from a buddy so didnt wanna have to waste money on new stuff if these worked for the time being I was going to get the BTR SP001 if these didnt end up working out
Old May 27, 2025 | 01:08 PM
The BTR shaft kit is arguably the best, but can't go wrong with CHE. The very best is Manton's trunnion kit, but big $$$.
Old May 27, 2025 | 01:11 PM
ramqooo's Avatar
Smile
Im probably gonna try CHEs new shaft mount trunnion kit seems like a mix of the shaft mount and normal trunnion kit
