Gen 3 Ironblock + Gen4 Rotating Assembly
Old May 29, 2025 | 10:28 AM
goatmanls2's Avatar
Default Gen 3 Ironblock + Gen4 Rotating Assembly
I have a 2005 Gen 3 Ironblock. It came with gen 4 rods and pistons from the factory. I would really like to make it a full gen4 rotating assembly. I have a 58x crank available to do so. My question is, what else has to be done sensor wise? I believe the cam sensor moves to the timing cover therefore I will need a gen4 timing cover? I plan to use gen4 wiring harness with this set up - IF - that is possible. Thanks in advance.
Old May 29, 2025 | 12:44 PM
bthomas's Avatar
You pretty much got it, but to recap you will need
58x crank wheel and specific sensor (the 24x one wont work)
a 4x timing chain wheel
gen 4 front cover with sensor
leave the rear mount gen 3 cam sensor in place (unless you like oil leaks)
Old May 30, 2025 | 07:32 AM
goatmanls2's Avatar
Thank you very much! I also heard that the knock sensors are on the side of the gen4 engine, and with the gen3 engine, they are in the valley cover. Is this going to be an issue?
Old May 30, 2025 | 07:55 AM
bthomas's Avatar
I assumed that you would be using a newer ecu along with the gen 4 harness. It would be already equipped to use the side mount sensors.
Old May 30, 2025 | 08:14 AM
goatmanls2's Avatar
yes I am using gen4 harness and ECU. Does the gen3 block have these features already available to put the knock sensors on the side of the block?
Old May 30, 2025 | 08:23 AM
bthomas's Avatar
Yes, the same cast in mounting bosses on the sides of the block are there for both generations.
Old May 30, 2025 | 08:51 AM
goatmanls2's Avatar
Thank you. Do you believe it is necessary to have the rotating assembly balanced after swapping cranks?
Old May 30, 2025 | 03:04 PM
Necessary is relative. Some guys here will tell you that they run 8 mismatched pistons, rings that have 500k miles on them, bearings from a 6 liter with 250k on them, on 4 different rod sets. And the crank…bought it off marketplace for $25 and it runs great.
The truth is it will run as is. Will it run great? Depends on how bad out of balance it is. Harmonics related to balancing….not harmonics related to crank torsional loads from combustion…will shake the bearings out of an engine if it’s out bad enough, and you’ll never feel it. At the same time, these harmonics will fight the engine from turning rpm. Fight meaning it will work against it to make its peak torque where it’s supposed to. It’s still gonna make peak torque, just lower. This is what ALL harmonics do in an engine…or any machine for that matter.
Personally I would balance it. Sure it’s $300…or whatever depending on where your at, but it’s a lot cheaper to do it right once, than to do it twice. Now if your just building a throw-away engine to go do donuts with and raise sand…send it.
Having said this, I have seen very high end race engines overbalanced by quite a bit purposely to achieve better acceleration characteristics. Not more peak power, but more power under the curve to make acceleration quicker…which corresponds with what I mentioned earlier about torque parking lower than it potentially could.
