Which Oil Pump?
Old Jun 24, 2025 | 08:03 AM
goatmanls2's Avatar
Default Which Oil Pump?
Gen3 ironblock with gen4 rotating assembly. will be cammed and then eventually turbo'd down the road. What aftermarket oil pump is most likely recommended?
Old Jun 24, 2025 | 10:50 AM
CattleAc's Avatar
I'd probably use a Melling 10295...
Old Jun 24, 2025 | 10:52 AM
goatmanls2's Avatar
thank you. thats what I had picked out. was between 10295 / 10296 and the m295hv
Old Jun 28, 2025 | 06:35 PM
grinder11's Avatar
If you're going to run an oil cooler, which you may wanna do@turbo time, I'd go with the 10296......
