Heads cam intake build suggestions
yea I actually do plan on buying injectors I was thinking 42lb but that’s somthing I’m looking for input on. Also wondering if my stock fuel pump will handle everything. It’s an OEM pump I just put in 2yrs 1000miles ago. And my plan is to do a tune after everything is together no doubt👍
I'm going to create a build thread of my car soon and I also want to do something of a tutorial on pcm tuning primarily drivability stuff For the big cams because They really can be tamed, and the steps needed to do so I think are a lot simpler. Then some of the earlier threads an info that is written out there. It's pretty straightforward how I do it.
I've taught myself how to do all this over the years and I believe a lot of you guys could get the software and help yourselves along, However I think at some point I really do want to help others out with their tunes because there's no reason any good combination of parts can't drive just like stock with a little bit of patience and forethought given to the maps.
My current setup is 376ci" 11.9:1cr with a 234/246 113 cam with 14° overlap @ 0.050" zero issues
My car cold starts goes straight into gear and drives off just fine Even when it's cold It just gets Even smoother as it warms up just like stock without any driveabillity issues. It's daily drivable complete I can even make it through the McDonald's drive-thru and turn the car off so they can hear me at the speaker and then turn it right back on and drive creep forward just the same when it's hot without surging lmao.
Folks tons of overlap with the older carbureted stuff and never complain you Just have to think about your tune-up like an older machine, You got to twist that distributor back and forth until you get the base dialed in and then go from there right? Yeah more to come!
OP, to put some perspective, he’s referencing an auto. You can live with more when you have an auto stalled correctly. That said, what are you really gaining with a donkey stick? A little more top end, sure. Great at the track, big power under the curve matters more than this post suggests. “Small” cams have performed very well at the track with good manners. It’s your build, but when more voices are suggesting caution - maybe there’s something there. There’s always one guy that’s the expert and better than all the rest of us.
